FS: Daimond Audio amp D7054
Old Jul 20, 2008 | 01:31 PM
luvsspeed's Avatar
Default FS: Daimond Audio amp D7054
Looking to let go of a GREAT Amp for the Car or Truck. I had them pushing two JBL's and the Bass was deep and constand thru the volume levels.
If your Serious please call 646-261-8866. Willing to meet w/in the NYC five boro area.
including the specs...
Brand: Diamond Audio
Model: D7054
MSRP: $849.99
Output power @1% THD 1kHz 14.4 volts
Stereo @ 4 ohms 4 channels x 53 watts
Stereo @ 2 ohms 4 channels x 97 watts
Bridged @ 4 ohms
2 channels x 195 watts
Output power @1% THD 1kHz 12.5 volts
Stereo @ 2 ohms 4 channels x 96 watts
Bridged @ 4 ohms 2 channels x 193 watts
Distortion at 50Watts x 4, 1kHz 14.4 volts .09% @ 4 ohms
Input sensitivity 150 MV to 8.5 volts
Frequency response (+- 1dB) 10Hz- 85 kHz
S/N (A weighted, below clipping,min gain >98 dB
Damping Factor @ 100Hz, 4 ohms >312
Idle current 2.22 amps
Maximum current consumption,unclipped 49 amps @ 380 watts
Efficiency at 1/3 power, 2 ohm per CH. 35.5%
Efficiency at full power, 2 ohm per CH. 54%
Crossover slope 18dB/octave
Crossover range, lowpass 50Hz-5kHz
Crossover range highpass 50Hz-5kHz
Dimensions 19.5" x10.5"x 2.94"
Additional Measurements
Out of Regulation: 1kHz 9.8 volts, 20Hz 11 volts
Power out at 20Hz 1%THD 97 watts x 4
Slew rate (RCA input) 11.5 V/usec.
vtecguy01
Sep 17, 2006 05:10 PM
tca0bell
Audio / Security / Video
Feb 27, 2005 09:17 AM
CHONCH
Sep 10, 2003 09:43 PM
yoyoyo
Apr 15, 2003 06:54 PM
Liquidgsr
Oct 26, 2002 10:31 PM
