fuel pump , right?
I am working on a 89 crx , I replaced the main relay and ignition switch last summer and now the car will not start again. I pulled the main relay down and tried to start the car , the relay will click like it should for priming but no fuel pump noise. Should i replace the fuel pump?
check your wiring before you go droping some$$$ for a pump. the main relay goes to the ecu for a ground command so check it out. there is a thread on it somewhere here, try to find it.
see if there is voltage to the pump check the wires under the rear seat(or storage compartment if crx) if there is voltage its most likely the pump. you can also try cycling the key on while someone else bangs on the bottom of the tank real hard with a rubber mallet if it comes on then the pump is shot
juanchoenuncrx
Aug 29, 2007 07:59 AM
