Why is Brake Free Play Adjustable?
alos chech to make sure your rear drums are properly adjusted, the best way to do this is by using the e-brake ....how many clicks of the e-brake handle till the rear drums start draging? should be between 7-10 clicks till full engagment.
if the rear drums are out of adjustment there will be excesive play in the brake pedal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superex87 »</TD></TR><TR><TD CLASS="quote">alos chech to make sure your rear drums are properly adjusted, the best way to do this is by using the e-brake ....how many clicks of the e-brake handle till the rear drums start draging? should be between 7-10 clicks till full engagment.
if the rear drums are out of adjustment there will be excesive play in the brake pedal.</TD></TR></TABLE>
I totally forgot about this having rear discs... Rear drum adjustment will help alot!
pityocamptes
19
Mar 2, 2012 02:26 AM
datssoled
Jul 12, 2007 07:25 PM
Dan GSR
29
Mar 5, 2003 11:34 AM
