Low Fuel Light - JDM cluster, CRX.
Old Jul 19, 2008 | 10:31 PM
Ldo's Avatar
Ldo
Default Low Fuel Light - JDM cluster, CRX.
Has anyone got this to work on the JDM cluster? I've searched and found very little information about how this is wired up. Do I need the whole DA Integra fuel pump assembly to make this work? What does a DA fuel level sensor look like?
Thanks ahead.
Old Jul 20, 2008 | 08:27 AM
black0hatch's Avatar
Default Re: Low Fuel Light - JDM cluster, CRX. (Ldo)
i did a dc cluster once and wanted to get it to work too. i read on here you gota use the whole da pump set up. never done it though.
Old Jul 20, 2008 | 02:34 PM
Crx Jimmy's Avatar
I would swap the whole assembly out of the da, if the tank fits I would use the whole tank as well, I think its only 1 extra wire to hook up
Old Jul 20, 2008 | 03:04 PM
4DRmafia's Avatar
i still would like to know how to do this sometimes soon.
Old Jul 20, 2008 | 04:57 PM
nsxmatt's Avatar
If it's anything like my EG6 you would need to swap the fuel tank with one from a RHD crx and run the wires and pin them out. There was a completely different float for the low fuel on the rhd cars seperate from the fuel pump.
ajjct
May 21, 2013 01:19 AM
jmaze
Oct 24, 2007 07:31 PM
JDM_Ej
Aug 11, 2005 04:05 PM
naya1civic
Jun 13, 2004 03:59 PM
hatchii
Nov 4, 2002 02:43 PM
