Cable B18a tranny, clutch/flywheel options?
Old Jul 19, 2008 | 08:18 PM
impreziv's Avatar
Default Cable B18a tranny, clutch/flywheel options?
I have an 89 EF civic Si. I am installing an OBD1 B18b motor, and going to be using a cable tranny from a B18a (93 i think).
my question is, what clutch/flywheel combo can i use?
i checked exedy's site, and the part number for the 91-93 Integra clutch is different from 94-01. so i assume i cant use a 94+ clutch on my 93 tranny. what about the flywheel? can i mix and match? (like maybe a 95 flywheel and a 93 clutch?
im guessing that i can use 91-93 clutch any flywheel, i just want to confirm before i order the parts.
Old Jul 19, 2008 | 09:18 PM
JScott3d's Avatar
you can use the flywheel and pressure plate as they are the same for all b-series. throw outs are different between hydro and cable obsiouvies. The only difference in the clutch are the input shaft size. 90-91 are 1in and some 92-93 are also but most are 1 1/16 same as the hydro.
Old Jul 19, 2008 | 09:47 PM
impreziv's Avatar
Default Re: (JScott3d)
great, ill order the clutch/flywheel combo for the 90-93 integra then. the package im looking at comes with a new release bearing and pilot bearing.
Old Jul 20, 2008 | 10:16 AM
djstevehawken's Avatar
Default Re: (impreziv)
be sure to find out which cable tranny you have.. I was sold a "93" Integra tranny and it turned out to be a 90-91 which has a different clutch then 92-93. The flywheels are the same though.
Old Jul 20, 2008 | 10:53 AM
D16SiHatch's Avatar
Default Re: (djstevehawken)
yea what he said. 90-93 are not all the same! if you order the clutch for a 90-91 and you have a 92-93 tranny, it will not work. and also vice versa. be very sure what year trans you have before ordering the clutch.
diamondstarsforever
Transmission & Drivetrain
Mar 8, 2010 05:13 PM
daidilus
Jan 6, 2006 04:59 AM
Origin
Sep 11, 2005 08:00 PM
89a6T
May 9, 2004 04:27 PM
DA-B16
Mar 28, 2004 11:55 PM
