Belts squeaking
Old Jul 20, 2002 | 05:50 PM
Martaigne's Avatar
Default Belts squeaking
No, they're not loose, and there's no oil on the pulleys or belts.
I checked the Haynes manual and the belts seem to be a bit tighter than suggested. If they're tighter would that cause them to squeak? It also causes a touch of hesitation in my engine, usually under 3k rpms, but the hesitation stops when the squeaking stops. I know that wouldn't be the case if they were loose, because then the pulleys would slip and allow the engine to spin freely.
Also, is there a better way to judge their position than 'use your thumb and press the belt, measuring the slack'?
Old Jul 20, 2002 | 10:19 PM
Martaigne's Avatar
Default Re: Belts squeaking (martaigne)
bump
This can't be that difficult of a question.
Old Jul 21, 2002 | 05:16 AM
Chiovnidca's Avatar
If the belts still squeek when they are properly adjusted they may be glazed. Useing belt dressing or replaceing them are your options. The belts wouldn't explain your hesitation. Are you sure it's not your distributor making noise?
accordmatt
Feb 24, 2011 10:15 AM
93hatcheg
Sep 2, 2008 01:39 AM
JaeEK
15
Apr 21, 2008 06:36 PM
satan_srv
Oct 22, 2002 11:33 AM
hobo79
Feb 22, 2002 03:40 PM
