Code 13 After Ls swap in HF
Old Jul 19, 2008 | 06:36 PM
HM_CRX's Avatar
Default Code 13 After Ls swap in HF
Okay so I bought a white 89 CRX HF, and a 91 DA integra.
My homeboys from a local shop did the swap, the motor runs pretty strong with the stock PR4 but i'll probably use a PG7 i have.
Well, my CEL code is #13, atmospheric pressure. Does anyone know how to fix it or where that is located?
My friend also did a B18a1 swap into his 91 Crx si and used the PR4 ecu with no CEL's.
Is it the one black box on the HF's firewall?
Any help apreciated
BTW I lost my password, i'm not a noobie, member since 05 under z6_obd1_EF, just thought i'd mention that
Old Jul 19, 2008 | 06:45 PM
z6_EF_obd1's Avatar
Default Re: Code 13 After Ls swap in HF (HM_CRX)
OOPS! I guess i had my user name wrong, but i got it now, i reposted my question under my old username. member since 04,
Old Jul 19, 2008 | 07:53 PM
Aesthetic Gains's Avatar
Dos Pupusas
Default Re: Code 13 After Ls swap in HF (z6_EF_obd1)
If I remember correctly the baro/atmo pressure sensor is located next to the ECU. Right underneath the dashboard. Bolted on the pillar. Passenger side.
Old Jul 20, 2008 | 08:19 PM
z6_EF_obd1's Avatar
Default Re: Code 13 After Ls swap in HF (Tonio)
thanks, i'll check it out tomorrow
Old Jul 20, 2008 | 09:40 PM
dephtone's Avatar
Yeah its a little black box almost looks like a relay, has 3 wires coming out of it. Pick up in a junkyard parts stores was like 200 bucks for it. Mine had the same issue.
Old Jul 21, 2008 | 06:50 AM
jlicrx's Avatar
Default Re: (dephtone)
usually, when you get code 13, it is not the PA sensor causing the problem - more than likely it is a problem with the MAP sensor or a vacuum problem - this is the PA sensor
Old Jul 23, 2008 | 04:18 PM
z6_EF_obd1's Avatar
Default Re: (jlicrx)
thanks for the info guys.
ok, my 91 integra did not have a CEL so i really doubt its the MAP sensor.
I'm going to check it right now...
Old Jul 23, 2008 | 04:33 PM
z6_EF_obd1's Avatar
Default Re: (z6_EF_obd1)
well, I just went to check it and it gave me a code 43?????? and 13.
I am obd0 so there's no code 43...
I took the PR4 off and plugged in my PG7.
The CEL is GONE!!! however i did not drive it i just had it iddleing.
BTW, it iddled i little uncommon, it almost died in a few ocasions.
Is this normal for PG7/B18 combos?
z6_EF_obd1
Jul 19, 2008 07:03 PM
redline76
Jan 15, 2007 12:12 PM
crxhf19
Feb 2, 2005 10:48 PM
crxhf19
Feb 2, 2005 07:39 PM
pdiddyparsons
Apr 16, 2003 07:07 PM
