headlight conversion
Old Jul 19, 2008 | 01:43 PM
Outraged182's Avatar
Default headlight conversion
I made a post earlier about doing a front end conversion on a CRX...
Now I have a 4dr EG and I basically want to keep my bulbs since they are PIAA lights but they are H3... made for a EG housing, not the 9005 and 9006 lights like the high and low beams are in an EF set up. SOOooo... can I just mod the wiring and slap the H3 bulbs into the housing for the regular EF low beam bulbs?
if not... is it a huge bitch to mount EG lights into the CRX? I know it will require some customization, but i just need some help to see what i wanna do with a project I've got in mind
Old Jul 19, 2008 | 02:11 PM
tico's Avatar
Default Re: headlight conversion (Outraged182)
okay well first see if the bulbs fit if so then sure or just modify ur headlights to accept those bulbs. then take the plugs find ur pos&neg wires then wire it up. pretty straight forward. if the lights dont work u probably have the wires crossed. make sure when ur all done u solder and heat shrink ur connections .
sumyungguy
Nov 8, 2004 06:51 AM
97teg415
Aug 21, 2002 11:25 PM
c1hatch
May 10, 2002 01:45 PM
