Blox FPR - Anyone using? Opinions?
Old Jul 19, 2008 | 05:01 AM
pcguy760's Avatar
Default Blox FPR - Anyone using? Opinions?
I have a Blox adjustable FPR like the one pictured below and I would like to use it since my car will be turbo soon - would you guys recommend using this type or is anyone using this?
I figured that when the time comes to get it tuned, the tuner would probably prefer having one of these...
Old Jul 19, 2008 | 09:31 AM
Garcia-Racing's Avatar
Only if its 1:1, increases fp with boost
Old Jul 19, 2008 | 09:35 AM
yakuza's Avatar
This is identical in design to the B&M fuel pressure regulator I was sent for my setup and require the use of your OEM FPR (you have to cut the top of it and then insert it into the Blox one) but I wasn't impressed with it at all so got rid of it and paid extra for AEM one.
Old Jul 19, 2008 | 09:40 AM
aem is a nice piece
Old Jul 19, 2008 | 10:03 AM
pcguy760's Avatar
Default Re: (Garcia-Racing)
Hmmm, well I already have it and I cannot return it, so is it safe to use it and will it work well with boost? I am going to be using RC 550cc injectors as well and the ECU is running a Crome program...
Old Jul 19, 2008 | 10:05 AM
your tuner will prefer a 1:1, I'm sure, we have done turbo cars with the b&m style fpr, but kinda a pain in the butt.
Old Jul 19, 2008 | 11:23 AM
non-VTEC's Avatar
Default Re: (pcguy760)
it will work fine....although an aeromotive one will work better.
since you already have it just use it.
Old Jul 19, 2008 | 12:05 PM
pcguy760's Avatar
Default Re: (non-VTEC)
Ok great, I wanted to make sure it was safe and will not leak, etc.
Old Jul 19, 2008 | 04:00 PM
The only problem I can remember having was not being able to lower fuel pressure enough, like below 55psi, with the use of a walboro 255. I had to drill open a relief port, they may have fixed it now.
Old Jul 19, 2008 | 07:57 PM
mtber's Avatar
Default Re: Blox FPR - Anyone using? Opinions? (pcguy760)
You really don't "need" an FPR for most basic setups.
Old Jul 19, 2008 | 09:16 PM
pcguy760's Avatar
Default Re: Blox FPR - Anyone using? Opinions? (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">You really don't "need" an FPR for most basic setups. </TD></TR></TABLE>
What about me using RC 550cc Injectors?
Old Jul 19, 2008 | 09:53 PM
ATYPR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcguy760 &raquo;</TD></TR><TR><TD CLASS="quote">
What about me using RC 550cc Injectors?</TD></TR></TABLE>
I'm running 880cc injectors with a stock FPR
Old Jul 19, 2008 | 11:13 PM
mtber's Avatar
It will be fine
Old Jul 19, 2008 | 11:21 PM
pcguy760's Avatar
It will be fine </TD></TR></TABLE> - Crap I am glad I did not open it from its packaging - guess I can sell that ****
Old Jul 19, 2008 | 11:23 PM
pcguy760's Avatar
Default Re: Blox FPR - Anyone using? Opinions? (ATYPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATYPR &raquo;</TD></TR><TR><TD CLASS="quote">
I'm running 880cc injectors with a stock FPR</TD></TR></TABLE>
880cc injectors with stock fpr in what? What is your setup?
Old Jul 20, 2008 | 12:45 PM
pcguy760's Avatar
Ok I just thought, if I use my Walboro 255 Lph Fuel pump and the stock FPR with the RC 550cc injectors for my Turbo H22A (6 PSI only), will the Fuel pressure be too high??
Old Jul 20, 2008 | 12:55 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcguy760 &raquo;</TD></TR><TR><TD CLASS="quote">Ok I just thought, if I use my Walboro 255 Lph Fuel pump and the stock FPR with the RC 550cc injectors for my Turbo H22A (6 PSI only), will the Fuel pressure be too high??
It should be fine.
Old Jul 20, 2008 | 01:01 PM
pcguy760's Avatar
It should be fine.</TD></TR></TABLE>
Thanks Phearable
BTW, I found this interesting post which anyone else with who might have the same dilemma as me would find useful as well ...
https://honda-tech.com/zerothread?id=755923
HTNoob
Jul 27, 2007 07:11 PM
KRWTEK1
Feb 25, 2007 06:18 AM
TurbodTegSfaria
Oct 26, 2006 05:30 PM
b20vtechb
Mar 25, 2005 04:02 PM
Lei Siew Long
Aug 30, 2001 10:39 PM
