DLC Data Link Connector, 98 Accord LX, VTEC 4 Cyl, Obtain Codes Manually?
Old Jul 18, 2008 | 07:33 PM
cc-98accordlx's Avatar
Default DLC Data Link Connector, 98 Accord LX, VTEC 4 Cyl, Obtain Codes Manually?
Well maintained vehicle; everything works. Recent MIL lamp illuminated/stays on; am trying to ascertain the source/issue.
16 pin DLC on vehicle uses pins 4, 5, 7, 9, 14 and 16. Which are the 2 correct pins to connect, for manually reading stored DTC codes, via flashing MIL/CEL lamp (long and short flashes/pulses technique)?
Have seen other documentation on this subject depicting different DLC and other numbered pins in use; also warning posted when connecting incorrect pins, can damage other onboard equipment.
Am seeking the experienced/experts to clarify this issue. Appreciate any assistance. Did try to instant message another member on this subject; however, I'm "Trial" member status, and that feature is not yet available. Thanks again for any help.
Old Jul 21, 2008 | 05:30 PM
99accordFX's Avatar
Default Re: DLC Data Link Connector, 98 Accord LX, VTEC 4 Cyl, Obtain Codes Manually? (cc-98accordlx)
wy cant u just get a code reader and get it automaticly \
Old Jul 21, 2008 | 06:11 PM
YeuEmMaiMai's Avatar
http://www.v6performance.net look under 6th gen section and there are a bunch of sticky threads and I believe it is under tech information
bassysingh
Mar 3, 2017 10:17 AM
alexkharden
May 18, 2015 07:24 PM
sickgsx
Nov 1, 2009 08:55 PM
bob2000
Apr 23, 2005 06:18 PM
B16A2
Jul 22, 2002 07:44 AM
