steering rack woes
Old Jul 18, 2008 | 04:26 PM
d16efsedan's Avatar
Default steering rack woes
ok i need some advice on what could be wrong with my steering rack.i can take and turn the wheel 1/4 of the way and the wheels start to turn and when im in a corner and hit chatter bumps my wheels do not respone with my steering wheel(say im turning and my wheels start to turn when i hit bumps but i cannot steer out of it as turning the steering wheel does nothing.......and ideas?
Old Jul 18, 2008 | 04:31 PM
IndySporty's Avatar
Default Re: steering rack woes (d16efsedan)
it almost sounds like the knuckle at the base of the column is loose or something maybe?
Old Jul 18, 2008 | 05:56 PM
Mr.Death's Avatar
Have you looked over your balljoints and bushings?
Old Jul 18, 2008 | 06:02 PM
d16efsedan's Avatar
Default Re: steering rack woes (Mr.Death)
no i havent,i think the rack is just going to ****,its really bad.
Old Jul 18, 2008 | 10:52 PM
BoombasticSloth's Avatar
Have you adjusted the rack guide screw on the steering rack?
Old Jul 18, 2008 | 11:00 PM
d16efsedan's Avatar
Default Re: steering rack woes (BoombasticSloth)
no i was reading up on how to do it earlier.might give it a shot tomorrow...
Old Jul 19, 2008 | 01:36 AM
beana's Avatar
i'm guessing you don't have power steering
be honest it's one of two things either it's the ball joint where the spindle meets the lower control arm ,or it's the tie rod end ....you didn't give enough info so i can't tell you which side but when you go down the street let go of the wheel for a second which ever side it pulls to inspect that side
Old Jul 19, 2008 | 02:08 AM
d16efsedan's Avatar
Default Re: steering rack woes (beana)
yes i have power steering....
Old Jul 19, 2008 | 10:50 AM
beana's Avatar
check your power steering fluid then test your pump you'd be surprised how many times people came in thinking something was seriously wrong and there fluid was just low
Old Jul 19, 2008 | 11:12 AM
d16efsedan's Avatar
ok ill give it a shot....
White_EG1
23
Apr 12, 2016 08:34 PM
camo_crx
Mar 27, 2008 07:31 AM
DA9_DAD
Oct 3, 2005 06:55 PM
jabroni95gsr
Feb 13, 2003 04:12 AM
