idle problems
Old Jul 18, 2008 | 02:37 PM
jah808_eg's Avatar
Default idle problems
i got a 95 eg and 96 ek....cant find out y the idle pulses....there are no check engine lights or bad codes....any suggestions?
Old Jul 18, 2008 | 04:07 PM
turbocivic1984's Avatar
Default Re: idle problems (jah808_eg)
hey check this site out.. its helping me out with same problem....
http://www.ef-honda.com/ben/Badidle.php
Old Jul 18, 2008 | 04:58 PM
jdmdikk's Avatar
Default Re: idle problems (turbocivic1984)
if the cars are idleling its probably your throttle body..dats what i think
Old Jul 18, 2008 | 05:21 PM
Mikej425's Avatar
It's a very very common problem, usually a dirty iacv (idle air control valve)
undo it and spray it out with brake cleaner, let it dry completely and put it back on and it should fix it.
use the search tool and you can find tons of diy fixes for this
Old Jul 18, 2008 | 06:18 PM
vlc92189's Avatar
Default Re: idle problems (Mikej425)
it could be that because the iacv or ur idle screw is turned to high, in my car, if the idle screw is to high, then it surges.. try that maybe?
dc4b20
22
Dec 3, 2012 09:54 PM
Thatssojdm
Aug 5, 2008 07:59 PM
4gen
Jan 11, 2004 05:28 PM
diLUDEd
Aug 22, 2002 10:08 PM
