Lighting HID/Xenon kits, Retrofits and Associated Topics
HID's in OEM Integra lights
Old Jul 18, 2008 | 01:51 PM
fisherboy1118's Avatar
Default HID's in OEM Integra lights
Hey quick question, If i buy a nice set of HIDs and just put them in my factory 01 integra housings are they gonna look like ****? Are the factory lenses considered projectors?
Old Jul 18, 2008 | 02:20 PM
D-Atk's Avatar
you will be fine, I have HID's in my factory housing no problems!
Old Jul 18, 2008 | 02:22 PM
bakertime's Avatar
Default Re: HID's in OEM Integra lights (fisherboy1118)
Yeah, they're projectors, but with a pretty weak lens. I had this setup with 6000k HID's for a bit, and it honestly wasn't that bad. Recently did a TSX retro though, and I'll never look back. It's better then stock, IMO, but don't expect OEM HID output.
Old Jul 18, 2008 | 02:34 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fisherboy1118 &raquo;</TD></TR><TR><TD CLASS="quote">Hey quick question, If i buy a nice set of HIDs and just put them in my factory 01 integra housings are they gonna look like ****? Are the factory lenses considered projectors? </TD></TR></TABLE>
All 3rd gen Integras have halogen projectors.
However, the problem with stuffing a HID capsule into them, is the beam pattern.
The stock lights were designed to spread the 1000 lumen output the stock bulbs produce over a reasonable spread. When you suddenly have 3200 lumen output from HID, you have 3 times the light, but none of the true benefits of a proper HID headlight. HID headlights are designed to make use of the extra light through a wider beam, with less of the light focused in the center than a halogen light. Too much light directly in front of the car actually makes it harder to see, due the larger difference between lit and unlit ground.
I would only bother with HIDs with a proper HID projector retrofit. With the stock projectors, a 9012 HIR bulb (or modified 9005 bulb) is about as much light as you can actually use, and is significantly cheaper than HID.
Old Jul 18, 2008 | 03:03 PM
p nut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fisherboy1118 &raquo;</TD></TR><TR><TD CLASS="quote">Hey quick question, If i buy a nice set of HIDs and just put them in my factory 01 integra housings are they gonna look like ****? </TD></TR></TABLE>
YES. Please do not do this. It is illegal, unsafe and looks horrible. I want to take a baseball bat to every one of those PnP HID's on Civics, Integras, Mustangs, etc.
And there is no such thing as "nice" plug and play HID's. Get yourself a nice set of retro-fit HID's.
Old Jul 18, 2008 | 07:37 PM
rhino87's Avatar
Default Re: HID's in OEM Integra lights (p nut)
I borrowed my friends HID kit and put it on my 99 integra and I was impressed. I thought it would look like crap but really it looked good. It was just like stock but brighter, the cutoff was still there. I don't know why everyone hates...just borrow someones kit for a night and try it yourself.
Old Jul 19, 2008 | 12:56 AM
DiMpL3s.'s Avatar
Default Re: HID's in OEM Integra lights (rhino87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhino87 &raquo;</TD></TR><TR><TD CLASS="quote">I borrowed my friends HID kit and put it on my 99 integra and I was impressed. I thought it would look like crap but really it looked good. It was just like stock but brighter, the cutoff was still there. I don't know why everyone hates...just borrow someones kit for a night and try it yourself.</TD></TR></TABLE>
x2
Old Jul 19, 2008 | 01:13 AM
__oversea's Avatar
Default Re: HID's in OEM Integra lights (DiMpL3s.)
non-projector will spill lots light, so other might not like it.
stock projector will just do fine. not great, but will do the job.
Old Jul 20, 2008 | 05:13 AM
devani's Avatar
Default Re: HID's in OEM Integra lights (__oversea)
you can be a ricer and be a danger to others as well...
Old Jul 20, 2008 | 08:52 AM
omnirage's Avatar
Default Re: HID's in OEM Integra lights (devani)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devani &raquo;</TD></TR><TR><TD CLASS="quote">you can be a ricer and be a danger to others as well...</TD></TR></TABLE>
OEM HIDs from other newer cars are just as god damn bright as any plug and play kit. Those [freak]ers nearly blind people too!
But if you can't stand seeing bright lights on the road, it's a good thing your pupil will automatically adjust to your lighting conditions, fools. DON'T STARE AT THE LIGHT IF YOU AREN'T GOING TO DO ANYTHING BUT BITCH ABOUT IT, lol.
Stock reflector headlights + PnP kits aren't nice at all though.
Old Jul 20, 2008 | 11:29 AM
95dc2teg's Avatar
Default Re: HID's in OEM Integra lights (omnirage)
i personally like my pnp hid's....to each their own i suppose
Old Jul 20, 2008 | 04:25 PM
steveo135's Avatar
Default Re: HID's in OEM Integra lights (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
I would only bother with HIDs with a proper HID projector retrofit. With the stock projectors, a 9012 HIR bulb (or modified 9005 bulb) is about as much light as you can actually use, and is significantly cheaper than HID.</TD></TR></TABLE>
x2 now go bake your headlights and retrofit for TMFW
Old Jul 20, 2008 | 06:58 PM
DiMpL3s.'s Avatar
Default Re: HID's in OEM Integra lights (steveo135)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveo135 &raquo;</TD></TR><TR><TD CLASS="quote">
x2 now go bake your headlights and retrofit for TMFW </TD></TR></TABLE>
Old Jul 21, 2008 | 01:48 AM
J. Funk's Avatar
It will look horrible. If you are going to do it, do a retrofit.
Old Jul 21, 2008 | 01:55 AM
EpicKills's Avatar
Banned
Default Re: HID's in OEM Integra lights (J. Funk)
Please buy a real HID kit and please dont try to do it yourself. im so tired of being blinded by people driving the other direction because either they didnt know what level to put their lights at or they dont realize the driver side isnt supposed to be the same level. Im with the guy with the baseball bat, Im not only hitting HIDs though Im hitting all the trucks too, being blinded by the car BEHIND you sucks.
Modified by EpicKills at 3:16 AM 7/21/2008
Old Jul 21, 2008 | 10:11 AM
Default Re: HID's in OEM Integra lights (EpicKills)
can you suggest where to get a "real" HID kit from?
Old Jul 21, 2008 | 10:18 AM
EpicKills's Avatar
Banned
Well you can check out the sponsors here on h-t. If I planned on getting an HID kit their is a friend I have on myspace who posts bulletins like on the daily about the work is garage does to try and get buisness. Id probably take it to him if I wanted HID... but Im not a fan of HID... no point.
If you want I can send you that guys contact from myspace, Ive seen cars he works on, I mean if its really his work Id vouche for it for sure.
Im just sayin lots of people try to retrofit, that being done means your guesstimating the levels for the beam where as someone in a shop or someone whos installed them a lot might be a lil more knowledgable in the level of light, see that its high intensity, it should be the only beam NOT shinning upwards cause the simple fact that its MORE intense. but people dont care they blind people, its annoying though.
Old Jul 21, 2008 | 11:26 AM
iH8RICERZ's Avatar
I had the philips 4300 plug and play kit in my integra a while back. I was very impressed with the light out put and the cut off, but there was still a slight glare. I ended up doing a retrofit and with the projectors I went with (cadillac cts projectors), it wasn't a huge upgrade. The only thing that was eliminated was the slight glare.......here's what my old plug and play looked like.
Haven't taken a pic with the retrofits yet.
Old Jul 21, 2008 | 12:05 PM
thanh4o8's Avatar
Default Re: HID's in OEM Integra lights (iH8RICERZ)
clean can't wait to see the retrofit
Old Jul 23, 2008 | 04:19 PM
steveo135's Avatar
Default Re: HID's in OEM Integra lights (thanh4o8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thanh4o8 &raquo;</TD></TR><TR><TD CLASS="quote"> clean can't wait to see the retrofit</TD></TR></TABLE>
x2 can't wait to see the "after" pic
Old Jul 23, 2008 | 04:38 PM
beaterman's Avatar
i love my plug n play kit. got it on here from operatic. here is the link. these lights are bad *** and easy as hell to install. plus come with long enough wires so you dont have to cut and extent like some other kits.
https://honda-tech.com/zerothread?id=1847971
Old Jul 23, 2008 | 04:49 PM
PACT man's Avatar
Default Re: HID's in OEM Integra lights (beaterman)
retrofit or GTFO!!!!!!!!!
Old Jul 23, 2008 | 07:28 PM
striker_18's Avatar
you were impressed with poor, very narrowed beam pattern?
Old Jul 24, 2008 | 07:07 AM
p nut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterman &raquo;</TD></TR><TR><TD CLASS="quote">i love my plug n play kit. got it on here from operatic. here is the link. these lights are bad *** and easy as hell to install. plus come with long enough wires so you dont have to cut and extent like some other kits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by operatic &raquo;</TD></TR><TR><TD CLASS="quote">
Now there is not a huge light output difference between 4300k and 12000k.</TD></TR></TABLE>
Wow, sounds like he knows his stuff. Why doesn't he put in his ad that his product is illegal for on-road use? I bet his buyers don't know that.
Old Jul 24, 2008 | 08:53 AM
bakertime's Avatar
Retrofits are illegal also...If you're really going to get technical, most of the things we do to our cars are illegal for "on-road use". Looking at it realistically though. HID's in a reflector housing are unsafe, and warrant the legal issues. HID's in an OEM halogen projector are less effective than OEM HID's, but are less of a safety issue because they have little glare beyond what a stock bulb or 9005 conversion would have. If they want to have a narrow beam and less output than say a TSX, then let em! It's still an improvement.
As I said above, I have a TSX retro in my Integra, but my prior PnP kit was just fine. This is just one of those never-ending debates...
