What the hell is wrong with my 98?
Old Jul 18, 2008 | 11:30 AM
AGENT 99's Avatar
Default What the hell is wrong with my 98?
98 dx d16y7
Overheating like a bitch. I have to pull over constantly to let it cool down. When I turn the heat on to help, no heat comes out. There is coolant all over the engine bay. Looks like it came from around the intake manifold.
Old Jul 18, 2008 | 11:31 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: What the hell is wrong with my 98? (AGENT 99)
let it sit and cool. pressure test it, fix the head gasket that has probably popped, put new head bolts in, fix the leak, let it eat.
Old Jul 18, 2008 | 11:36 AM
fmrprojects's Avatar
Default Re: What the hell is wrong with my 98? (boostedcivicsir)
you have a broken hose somewhere. get it pressure hecked and then replace the head gasket while you at it too. if you drove on it overheated, then most likely you warped the head
Old Jul 18, 2008 | 12:27 PM
AGENT 99's Avatar
Default Re: What the hell is wrong with my 98? (fmrprojects)
I've been getting some oil in the coolant reservoir lately.
For the past year, the car has had non-stop chronic overheating issues. I mean, badly.
Replaced the thermostat but anything longer than a 2 minute red light causes the stupid bitch to overheat.
Old Jul 18, 2008 | 02:45 PM
Memnoch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGENT 99 &raquo;</TD></TR><TR><TD CLASS="quote">I've been getting some oil in the coolant reservoir lately.
Replaced the thermostat but anything longer than a 2 minute red light causes the stupid bitch to overheat. </TD></TR></TABLE>
Is your fan coming on? Sounds like its overheating from the fan switch and/or relay, because it seems like its only overheating from a dead stop? Oil in your coolant reservoir is your 100% sign you popped the head gasket. Did the overheating start before or after the noticed oil?
Modified by Memnoch at 6:52 PM 7/18/2008
Old Jul 18, 2008 | 03:56 PM
94EG8's Avatar
Seagull Management
If you've got oil in the coolant think blown headgasket, warped/cracked head or cracked block. If its been overheated several times i'd say pull the engine and drop something else in, as the engine is probably cooked by now.
Old Jul 18, 2008 | 08:31 PM
AGENT 99's Avatar
Default Re: What the hell is wrong with my 98? (Memnoch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Memnoch &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by Memnoch at 6:52 PM 7/18/2008</TD></TR></TABLE>
Seems like before.
Coming in to work tonight ( I only live 3 miles from work- and it still overheated) I noticed when I parked and looked behind the car, a huge splatter/drip trail. You could see exactly where I drove in the parking lot. Earlier in the day, I refilled the radiator with coolant. I'm guessing its all gone now.
Old Jul 19, 2008 | 12:35 PM
Memnoch's Avatar
Yeah you are burning coolant and shooting the excess out the exhaust, your head gasket is blown and your pouring coolant into the combustion chamber as well as oil into the coolant system.
98hatchhonda
Jan 6, 2016 05:01 PM
Spawn_x
11
Dec 24, 2013 05:37 PM
Cashpoboy
Apr 14, 2008 12:33 PM
Jeff1119
Nov 14, 2007 10:07 AM
_Cyclone_
May 31, 2005 01:11 PM
