So the SOB will not start !
Old Jul 18, 2008 | 09:53 AM
free99's Avatar
Default So the SOB will not start !
OBD2B civic ITR motor
Am already out of ideas of what could be going wrong.. Pulled the motor out to do some cleaning on the bay and now it will not start..
I know am getting spark, if I pull the wire from the cap I can see a spark on all 4 of them
I am getting fuel b/c I smell it, and I see the injectors squirting
I have checked all my fuses 4times inside and outside
I have all 3 grounds
Starter cranks like a champ
I change dizzys
Anyone ? ? ?
I spend all-day yesterday and I could not get the SOB to start
Old Jul 18, 2008 | 10:00 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: So the SOB will not start ! (free99)
is it now flooded?
Old Jul 18, 2008 | 10:08 AM
free99's Avatar
I pulled all the pullgs out, they did have fuel .. i dryed them up and put them back in
Old Jul 18, 2008 | 10:10 AM
Mr. Badwrench
Default Re: (free99)
1fuel
2air
3spark (correct timing)
4compression
got all 4 it should run.
you didnt get the dizzy in 180* out? i know it isnt likely but ihave seen people do it.
Old Jul 18, 2008 | 10:15 AM
free99's Avatar
i have pulled the dizzy out and moved the gear 180 from were it was and still nothing .
when it cranks I place my hand by the TB i can feel vacum.
Old Jul 18, 2008 | 04:27 PM
turbocivic1984's Avatar
any luck?
Old Jul 18, 2008 | 04:30 PM
tonylor89's Avatar
Default Re: So the SOB will not start ! (turbocivic1984)
r u sure u didn't leave any like liquids in the pistons......but yeah check ur main relay and make sure ur timing is right.......
Old Jul 21, 2008 | 04:09 AM
free99's Avatar
nothing , what do you mean liquid on pistons ? am about to take it to a shop
Old Jul 21, 2008 | 05:58 AM
eg9matt's Avatar
this may sound stupid but charged the battery, the motor right now prob cranks but wont turn over right? it just doesnt have enough juice to start it up, also check your firing order
baldmofo
Oct 19, 2006 08:13 AM
hondaboy4life
May 8, 2006 06:44 AM
2kTeg
Feb 12, 2006 06:14 PM
bonestock92si
38
Aug 30, 2004 10:02 PM
Lo-Buck EF
Aug 22, 2003 05:40 AM
