no brake lights??
Old Jul 18, 2008 | 09:46 AM
keepitngga1's Avatar
Default no brake lights??
yes i tried searching and i still havent found a answer. i have 93 bubble but no brake lights come on..headlights work, turn signals work,. i checked the bulbs and they are not blown. anny idea where else to look?? if anyone has a wiring diagram for the brakes that would be veryy helpful.. thnks
Old Jul 18, 2008 | 10:01 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: no brake lights?? (keepitngga1)
check the brake light switch? its down thur on the pedal assembly
Old Jul 18, 2008 | 10:06 AM
Default Re: no brake lights?? (boostedcivicsir)
i already replaced the switch also so its not that
Old Jul 18, 2008 | 11:37 AM
94EG8's Avatar
Seagull Management
have you checked your fuses? kind of a stupid question i know but sometimes it happens. Also there is a fuse under the hood for it, the horn shares the same fuse and i think its either labled horn or stop light.
Old Jul 18, 2008 | 11:40 AM
fmrprojects's Avatar
Default Re: (94EG8)
check the instument panel light fuse. if hats out then the brake lights are out too. or just turn your headlights on and see if you have lights on the cluster. just go and check your fuses
Old Jul 18, 2008 | 08:16 PM
JDMCACKBOY's Avatar
Default Re: (fmrprojects)
Help this guy out fixing his Brake light problem
Old Jul 18, 2008 | 10:16 PM
stbdkills's Avatar
FUSE
Old Jul 18, 2008 | 10:26 PM
Former User's Avatar
If the fuse is fine, then check whether the ground wire is loose or disconnected.
z0mby
Dec 4, 2010 05:24 PM
JAYDmManny1331
Sep 16, 2009 10:43 PM
dankies
Feb 8, 2006 08:32 PM
b16a2pwr
Feb 14, 2004 02:28 PM
Jdmglenn
Oct 14, 2003 07:03 PM
