Is the EG bumper the same as the del sol?
Old Jul 18, 2008 | 05:01 AM
bosco500's Avatar
Default Is the EG bumper the same as the del sol?
Is the EG front bumper cover the same dimensions as the del sol?
Old Jul 18, 2008 | 05:06 AM
team_exceed's Avatar
Default Re: Is the EG bumper the same as the del sol? (bosco500)
i cant imagine they would be.. but ill bump it for you, so someone else can answer.
Old Jul 18, 2008 | 05:27 AM
davefromPA's Avatar
the answer is no they are not the same
Old Jul 18, 2008 | 06:16 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Is the EG bumper the same as the del sol? (davefromPA)
They don't even look the same man...
Old Jul 18, 2008 | 07:17 AM
davefromPA's Avatar
Default Re: Is the EG bumper the same as the del sol? (JDM_Ej)
even at that he is asking if they are the same dimensions which they are not.
Old Jul 18, 2008 | 08:37 AM
Loserkidwac's Avatar
Why are you asking...if you are wanting to put a lip for an EG on a Del Sol...then yes it willw ork...but other then that they are different...
Old Jul 18, 2008 | 12:01 PM
bosco500's Avatar
Default Re: Is the EG bumper the same as the del sol? (Loserkidwac)
I realize the bumpers look completely different. I should have been more specific. I need a front splitter and air dam for the del sol but dont have the time or resources to make one. I want to get the one that http://www.specialprojectsms.com/ makes for the EG, but I'm not sure if it will fit. If the bottom edge of the bumper is the same and the holes for the lip are in the same place I'm good to go.
Old Jul 18, 2008 | 12:52 PM
the holes for the lip aren't the same but you can drill new ones...I just ordered the ex/si lip for my Del Sol, I'll let ya know hoe hard it is to mount once i do it but from what I have read and seen it fits well
Old Jul 18, 2008 | 04:38 PM
KillBot's Avatar
Just remember, the 93-95 and 96-97 del Sol have different contours where a lip would go. Get a plastic lip and use a heat gun. The 93-95 sols are better for fitting an EG lip.
8300rpmallday
Feb 22, 2012 10:02 AM
xmrxnguy3nx
19
Nov 1, 2009 10:51 AM
bosco500
Jul 17, 2008 03:19 AM
Mr. Nickels
Jan 22, 2006 03:28 PM
soless
Oct 18, 2005 04:22 PM
