Swapping d16z6 into 96 civic ex (HELP)
Old Jul 17, 2008 | 09:21 PM
z00m's Avatar
Default Swapping d16z6 into 96 civic ex (HELP)
recently bought the ek back with a bad block and since i have a spare z6 i was thinking about swapping it into the ek.. if anyone knows and can explain everything that i will need or change out ill appreciate it..THANKS!!
Modified by z00m at 10:28 PM 7/17/2008
Old Jul 18, 2008 | 12:45 PM
z00m's Avatar
Default Re: Swapping d16z6 into 96 civic ex (z00m)
anybody?
Old Jul 18, 2008 | 01:16 PM
dblock8989's Avatar
the 96 is obd2 rite and the z6 is odb1 rite
Old Jul 18, 2008 | 01:38 PM
rSol93's Avatar
Default Re: (dblock8989)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dblock8989 &raquo;</TD></TR><TR><TD CLASS="quote">the 96 is obd2 rite and the z6 is odb1 rite</TD></TR></TABLE>
Right*.
Old Jul 18, 2008 | 03:16 PM
z00m's Avatar
yupp
Old Jul 18, 2008 | 03:54 PM
94EG8's Avatar
Seagull Management
Swap the longblock in, resuse your Y8 intake, exhaust, distributor and ECU. I think thats about it, someone tell me if i missed something.
Old Jul 18, 2008 | 08:52 PM
z00m's Avatar
thanks fellaz looking forward to it anymore useful tips or info?
Old Jul 18, 2008 | 09:27 PM
LumpyTheGrumpyCamshaft's Avatar
you can't run a 95 in a 96, has to be the same year engine as the chassis or newer per state regulatory crap. you might not pass inspection, and get ****.
a sohc is 300 from a junkyard just grab a 99 or something. easyer to swap in, no law headaches.
Old Jul 20, 2008 | 11:09 PM
z00m's Avatar
easy to say man..them swapz r hard to find ........
Old Jul 20, 2008 | 11:11 PM
Syndacate's Avatar
Default Re: Swapping d16z6 into 96 civic ex (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">Swap the longblock in, resuse your Y8 intake, exhaust, distributor and ECU. I think thats about it, someone tell me if i missed something.</TD></TR></TABLE>
Injector plugs are different, I believe, so cut the ends off a '92-'95 so they'll plug up.
Also, I'm not sure about - but the alternator plug might be different...also, the distributor that you mentioned, the plug is different there for sure.
Old Jul 21, 2008 | 05:33 AM
94EG8's Avatar
Seagull Management
Yeah, injector plugs are definately different, i'd just swap the whole fuel rail and injectors along with intake manifold, alternator plug is also different as you said, '92 - '95 is round, i believe '96 - '00 is square.
Old Jul 22, 2008 | 04:06 PM
dblock8989's Avatar
Yea even tho their diff they could still b used .......like he said if u have everything from 1 swap and the other.... just swap everything their both basically the same sohc are usually the same just minor parts that change
Old Jul 22, 2008 | 04:08 PM
dblock8989's Avatar
And for the dizzy just look for an adapter on ebay like 25 30 $$$ so hope this helps and just write if u need help
Honda_Mane
12
Jan 3, 2011 02:31 PM
9hatch6
41
Apr 13, 2005 08:09 PM
civichatch52687
Sep 4, 2004 12:24 AM
DevinW
May 27, 2002 10:48 AM
