bad throttle response at low rpm's...98 EK auto --> manual swap B20/vtec
i got a 98 civc hatch. did a full auto to manual swap. i got the wiring harness from a 97 civic coupe ex (dash & engine harness). I have a b20 block and b16a2 head. the problem i'm having is that when i stomp on the gas the engine revs fine. but, when i slowly take off the engine bogs, almost dies until i play with the gas and the rpm's are atleast 1500-2000 then its fine. Im sick of spinning at a light when i don't mean to. what could be wrong? the check light is always flashing as if the wire to check the code is jumped. wheres that wire located?
it sounds like a you need to recheap your computer box.
it happens to me when i swap engine from sohc to b-16
__________________
Autopartswarehouse.com
__________________
Claydooo
Mar 27, 2019 12:37 PM
