k20 miles NEED HELP FAST
Old Jul 17, 2008 | 07:50 PM
k20MEX's Avatar
Default k20 miles NEED HELP FAST
im looking to buy a rsx 2002 with 96 thousand miles it has been run but i like it tho i also like the gsr.all i want to know if a k20 still good with the much miles...thank you
Old Jul 17, 2008 | 09:02 PM
WhiteOnRice's Avatar
Compression test it. I swapped a k20a2 into my ep with 92k and it's perfect (after I replaced an injector).
Old Jul 18, 2008 | 10:06 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (WhiteOnRice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice &raquo;</TD></TR><TR><TD CLASS="quote">Compression test it. I swapped a k20a2 into my ep with 92k and it's perfect (after I replaced an injector). </TD></TR></TABLE>
Dumb question: How do you do a compression test on a K-series? Same thing as B-series? Pull coil packs, pull fuel or ECU fuse, unthread spark plugs, thread in tester, then crank 8-10 times?
Old Jul 18, 2008 | 04:42 PM
k20MEX's Avatar
but see im not gonna swap it im gonna buy the acurz rsx 2002 k20 with 96thousand and one of my friends at work told me that honda and acura are good even with alot of miles
Old Jul 19, 2008 | 11:04 AM
Default Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">
Dumb question: How do you do a compression test on a K-series? Same thing as B-series? Pull coil packs, pull fuel or ECU fuse, unthread spark plugs, thread in tester, then crank 8-10 times?</TD></TR></TABLE>
Yeah, it's standard on all fuel injector engines. I didn't crank it that many times though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20MEX &raquo;</TD></TR><TR><TD CLASS="quote">but see im not gonna swap it im gonna buy the acurz rsx 2002 k20 with 96thousand and one of my friends at work told me that honda and acura are good even with alot of miles </TD></TR></TABLE>
96k isn't a lot of miles for a Honda. Period. 96k really isn't a lot for most late model cars anymore.
Old Jul 20, 2008 | 05:03 PM
k20MEX's Avatar
well i dont know cuz i have a 1991 cutlass sierra with 75thousand and i got it at 65 thoudsand miles
Old Jul 20, 2008 | 05:28 PM
lazy dp's Avatar
get the rsx =]
Old Jul 20, 2008 | 06:55 PM
Pat_S's Avatar
Default Re: (k20MEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20MEX &raquo;</TD></TR><TR><TD CLASS="quote">well i dont know cuz i have a 1991 cutlass sierra with 75thousand and i got it at 65 thoudsand miles</TD></TR></TABLE>
Huh?
Old Jul 21, 2008 | 07:09 AM
k20MEX's Avatar
Default Re: (Pat_S)
nothink
Old Jul 21, 2008 | 07:10 AM
k20MEX's Avatar
Default Re: (lazy dp)
yea thats what i m gonna do by the end of august
Old Jul 21, 2008 | 09:22 AM
FullEP3's Avatar
From what I was recently told, compression test results can be skewed on K-series motors due to the "i"-VTEC function ...
Old Jul 21, 2008 | 12:01 PM
hawaiiancb74's Avatar
Default Re: (FullEP3)
told wrong
Old Jul 21, 2008 | 03:07 PM
FullEP3's Avatar
Default Re: (hawaiiancb74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawaiiancb74 &raquo;</TD></TR><TR><TD CLASS="quote">told wrong </TD></TR></TABLE>
and why is that?
I'll get some clarification on it ... but it makes sense. The variable timing adjusts only the intake cam ... so if the intake cam was advanced when doing the compression test, air could escape the intake valve due to being partially open, lowering the compression test results.
Old Jul 23, 2008 | 07:26 AM
You can compression test k-series the regular way but expect low numbers.
02+ k20a2
nominal: (?)
minimum: 135 psi
max var: 28 psi
http://www.team-integra.net/fo...Topic
Old Jul 23, 2008 | 10:22 AM
k20MEX's Avatar
whats thats?
Old Jul 26, 2008 | 10:36 AM
thetunersource's Avatar
i bought my ep3 with 91000 miles and turbo'd it at 92000 miles and it runs awesome! of course i did a compression test before i bought it
Old Jul 27, 2008 | 09:16 PM
k20MEX's Avatar
Default Re: (thetunersource)
im berly learning about cars so if you help me what compression test
Old Jul 27, 2008 | 11:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FullEP3 &raquo;</TD></TR><TR><TD CLASS="quote">
and why is that?
I'll get some clarification on it ... but it makes sense. The variable timing adjusts only the intake cam ... so if the intake cam was advanced when doing the compression test, air could escape the intake valve due to being partially open, lowering the compression test results.</TD></TR></TABLE>
we do comp test the same on the k a we do on the b .. the i vtec has nothing to do with it. the car would have to rev into vtec to even cause any such problem.. and for the most part its the same vtec system, the only differance is that the car can adjust but itself.. but when your sitting there tuning the car over its reving at about 60 rpms per min if you were just to hold it down.. and no you will not get lower numbers.. remove the fuel fuse, hook the guage in, push the go go pedal allthe way down and crank untill the guage stops moving.. then record the differance.. anything more than 5 percent differance requires a leak down test..
any other questions ill answer but i dont check here often because this sites full of jackasses.
TUR3Ovtec
Oct 17, 2013 02:41 AM
Fat Chick Magnet
Sep 28, 2006 06:24 PM
Mr.Death
15
Aug 18, 2006 02:10 PM
fafsa
Dec 3, 2004 12:10 PM
BolivianFuego
Nov 15, 2003 10:42 AM
