More Piston to Valve clearance questions...
Old Jul 17, 2008 | 06:52 PM
AFAccord's Avatar
Default More Piston to Valve clearance questions...
Don't I need to lock the rocker arms together so I can clay using the VTEC lobe? If so, how do I do this? If not, please explain why?
Old Jul 17, 2008 | 07:48 PM
Fkned's Avatar
Default Re: More Piston to Valve clearance questions... (AFAccord)
yes you have to lock them by switching the long and short pins in the rockers so they are locked.
rh76pogi's Avatar
here start reading...
https://honda-tech.com/zerothread?id=1891614
Old Jul 18, 2008 | 03:53 AM
AFAccord's Avatar
Default Re: More Piston to Valve clearance questions... (Fkned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fkned &raquo;</TD></TR><TR><TD CLASS="quote">yes you have to lock them by switching the long and short pins in the rockers so they are locked.</TD></TR></TABLE>
Thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rh76pogi &raquo;</TD></TR><TR><TD CLASS="quote">here start reading...
https://honda-tech.com/zerothread?id=1891614</TD></TR></TABLE>
I've already read that. I don't have a spring compressor, check springs, or a dial indicator, only calipers, hense I'm claying the motor. Thanks though.
tasco
12
Dec 9, 2008 02:39 PM
JDMTuner4Life
Apr 26, 2007 06:56 PM
dohmahklan714
Oct 2, 2006 09:19 PM
HIboost
Jul 12, 2006 09:27 PM
EVOLUTIONINNYC
Nov 12, 2004 04:14 PM
