Swap question
Old Jul 17, 2008 | 04:35 PM
Timberland237's Avatar
Default Swap question
what do i need for my d16y7 or y8 (si vtec if the block code isn't right i'm not at the garage right now.) swap into me 93 eg. I know i need to change th pc since the eg is OBD1. I will probably have to add some wires etc for certain parts. So what is the easiest way for me to do this, and what ecu will be needed.
Old Jul 18, 2008 | 07:57 AM
Default Re: Swap question (Timberland237)
so nobody has ever done this swap before? I looked in the faq forum and they really only talk about the b series obd2 engines into an eg. A little help would be appreciated.
Old Jul 18, 2008 | 09:08 AM
JdelMsolG's Avatar
you may possibly have to wire vtec.
other then that its a plug and play type of swap.
You'll need the corresponding ecu, which can easily be found by using the search function. goodluck
Iloveyourhonda92
Oct 12, 2014 06:15 PM
Eg9502
Sep 7, 2014 11:30 PM
streetcartuner
Jan 7, 2007 12:11 PM
hbkxtbone
Sep 23, 2004 10:09 AM
