Swap question
Swap question
what do i need for my d16y7 or y8 (si vtec if the block code isn't right i'm not at the garage right now.) swap into me 93 eg. I know i need to change th pc since the eg is OBD1. I will probably have to add some wires etc for certain parts. So what is the easiest way for me to do this, and what ecu will be needed.
Re: Swap question (Timberland237)
so nobody has ever done this swap before? I looked in the faq forum and they really only talk about the b series obd2 engines into an eg. A little help would be appreciated.
you may possibly have to wire vtec.
other then that its a plug and play type of swap.
You'll need the corresponding ecu, which can easily be found by using the search function. goodluck
Iloveyourhonda92
10-12-2014 06:15 PM
streetcartuner
01-07-2007 12:11 PM
