Idle Search
Old Jul 17, 2008 | 02:36 PM
shizkabob3421's Avatar
Default Idle Search
I need help! I've got a 93 si that idle searchs from about 800rpm up to 2500rpm constantly. I thought it was the TPS, I've replaced the TPS with a brand new one but that didn't fix a thing. I checked the voltage on the TPS and the ECM, they were both in check. I could really use some help the idle search is driving me crazy. Thanks
Old Jul 17, 2008 | 02:52 PM
eg8hardcore's Avatar
Default Re: Idle Search (shizkabob3421)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shizkabob3421 &raquo;</TD></TR><TR><TD CLASS="quote">I need help! I've got a 93 si that idle searchs from about 800rpm up to 2500rpm constantly. I thought it was the TPS, I've replaced the TPS with a brand new one but that didn't fix a thing. I checked the voltage on the TPS and the ECM, they were both in check. I could really use some help the idle search is driving me crazy. Thanks </TD></TR></TABLE>
is this when you are at idle? if so i'd check the iacv. Does it constantly do it or is it only on cold starts? If it is only on cold starts, it's just your car, nothing you can do, older cars do it for some reason. when i first start up my 92, it idle searches, then it idles super high, then it finally calms down.
Old Jul 17, 2008 | 03:16 PM
Default Re: Idle Search (eg8hardcore)
It constantly Idle searchs as long as the its in neutral or the clutch is depressed. How do I go about checking the iacv?
Old Jul 17, 2008 | 03:40 PM
check for vacum leaks first sir. spray all the vacume lines, and if it changes the idle, there is your problem. this is my last post for the day since i'm on trial, if you need help, pm austinkli.
Old Jul 17, 2008 | 03:44 PM
austinkli's Avatar
and now i can post as much as i want.
check out this thread man.
https://honda-tech.com/zerothread?id=2200841
it has directions in there because i am lazy and don't feel like typing.
Old Jul 17, 2008 | 04:15 PM
Default Re: Idle Search (austinkli)
thanks
Old Jul 22, 2008 | 12:23 PM
did you get the problem fixed yet?
E JAY 1
Mar 6, 2008 05:22 PM
easycheese
Jan 14, 2008 10:04 AM
jrd450r
Jun 25, 2006 09:14 PM
mikeunreal2
11
Mar 23, 2006 12:00 PM
NoPaiNT
Nov 2, 2004 12:39 PM
