Will the axle back fit
Old Jul 17, 2008 | 11:20 AM
zoso's Avatar
Default Will the axle back fit
Hey i have a 2000 civic wit a Apexi n1 cat back on it, i am trading the axle back for a 00 civic si stock axle back. Will it fit directly or will i have to weld it in. I know the n1 piping is like 2.36 or something around there but not sure what stock si is
Old Jul 17, 2008 | 11:39 AM
BlackDeuceCoupe's Avatar
HT White Ops
Default Re: Will the axle back fit (zoso)
I *think* it will work just fine!
Why?
I had a Tenzo R axle back on my HX that I wanted to use after doing a full Si swap - instead of the stock axle back.
The Si exhaust plumbing was larger than the HX, however...
All I had to do was elongate the two holes of the mounting flange, so the spring-loaded screws that hold it together didn't bind against the side(s) of the holes!
You'll probably have the same situation - in reverse...
I suspect all you'll have to do is play around with the holes on the flange...
Old Jul 17, 2008 | 02:29 PM
zoso's Avatar
Default Re: Will the axle back fit (BlackDeuceCoupe)
he has full stock si and i have full apexi n1, we are just trading axle backs, would it work out ok with out doing anything. I think it should.
Old Jul 18, 2008 | 02:24 PM
zoso's Avatar
Bump Does anyone know, this should be a pretty easy question...
Old Jul 18, 2008 | 04:23 PM
tonylor89's Avatar
it will be a direct bolt on for alll 92-00 civics......all integra 94-2001 will bolt onto civic n civics will bolt onto integras....easy n simple man... u should be cool garanteed
Old Jul 18, 2008 | 05:06 PM
zoso's Avatar
Default Re: Will the axle back fit (tonylor89)
Im pretty sure your right with my questiion, but integra and civic exhaust you cant sway out... just so you know
SubTitle
Sep 21, 2003 05:55 PM
SloCivicHMM
Aug 12, 2003 09:31 AM
01-0720
Jun 28, 2002 04:27 PM
