1990 ef si hatch problem please help
Old Jul 17, 2008 | 09:33 AM
ef8_crx's Avatar
Default 1990 ef si hatch problem please help
ok i got a 1990 ef hatch si and put a ls in and it wont stay on when i had the ls in my 91 dx hatch it ran perfect and now that i put it in my 90 si hatch it doesnt wont stay on there's fuel, timimg is right, and all liquads are there when i start it up with starter fuilds it say on but when i stop spraying it turns off and fuel pump is working main relay is good but i just wont stay on pleae help
Old Jul 17, 2008 | 09:42 AM
_Keith_'s Avatar
Check if you have fuel in the fuel rail.... make sure your injectors arent clogged...
Your not throwing any codes?
Old Jul 17, 2008 | 09:49 AM
ef8_crx's Avatar
Default Re: (_Keith_)
there fuel in the fuel rail how do i check of the injectors are cloged
Old Jul 17, 2008 | 07:32 PM
Aristotle's Avatar
Probably resistor box.
Old Jul 18, 2008 | 06:45 PM
ef8_crx's Avatar
Default Re: (Aristotle)
nope chaned it already
Old Jul 20, 2008 | 06:48 PM
ef8_crx's Avatar
anyone help please
Old Jul 20, 2008 | 07:12 PM
SiR4U2C's Avatar
check you main relay under the driverside dash and if its not burnt then check your ecu and make sure thats not fried as well.
redef90si's Avatar
Default Re: (ef8_crx)
possible vaccuum leak to your idle air control valve?make sure all those hoses are tight.I would clean you iacv out and maybe check your throttle cable?(makes sure it's adjusted to where it should be?) Also hows the fuel pump in your si?Just a few things to think about?
Old Jul 20, 2008 | 07:15 PM
SiR4U2C's Avatar
thats tru aswell, i would run thru a normal checkup on the motor before you do anything else, u might have forgot to hook a plug up or like red said a vacuum hose or something.
Old Jul 20, 2008 | 09:02 PM
elgil's Avatar
Default Re: 1990 ef si hatch problem please help (ef8_crx)
check your distribuitor wiring, the dx and si pins are diferent in the ecu
Old Jul 21, 2008 | 04:22 PM
ef8_crx's Avatar
THANKS PEOPLE ILL TRY THIS STUFF AND LET YOU GUYS KNOW HOW IT WENT
Old Jul 25, 2008 | 04:46 PM
ef8_crx's Avatar
anybody help please
Old Jul 25, 2008 | 05:33 PM
R015's Avatar
there was a recent thread about the same thing recently unless you're posting again...search for it
Old Jul 25, 2008 | 05:40 PM
ef8_crx's Avatar
thsi the only thread i strated
groutefhatch
Mar 25, 2016 12:01 AM
Z0831xiz
18
May 16, 2013 09:39 PM
Luke 91 ef
Jan 24, 2013 10:40 AM
Stephen90Si
10
Aug 16, 2009 10:56 AM
13sechatch
Jul 30, 2004 11:21 AM
