96 hatch - cel codes 17, 41, 65
Old Jul 20, 2002 | 12:29 PM
GRAVEDIGGER's Avatar
Default 96 hatch - cel codes 17, 41, 65
car is 96 hatch all stock throwing codes 17, 41, 65, what would cause this and how to fix i know what the codes mean vehicle speed sensor is defective or unplugged, 41 is primary oxygen sensor heater circuit malfunction and 65 is oxygen sensor heater secondary malfunction or defective . cars light are surging ,speedo jumps eratically from 0-120 without car moving what to do to fix need help asap thanks
[Modified by rp2000r, 10:59 PM 7/20/2002]
Old Jul 20, 2002 | 01:27 PM
Default Re: please help cell codes (rp2000r)
anyone?????
Old Jul 20, 2002 | 02:27 PM
doc's Avatar
doc
Default Re: CODES 17,41,65 (rp2000r)
hmm, maybe a bad gound problem. (I've seen this on a non honda). Check the ground wires. Just to be save, remove the battery poles, check for oxitation, clean and reattach.
Did you something on your car befor this happens?
Christian
Old Jul 21, 2002 | 10:40 AM
Default Re: CODES 17,41,65 (doc)
help
Old Sep 11, 2012 | 07:44 AM
dirty19's Avatar
Ridin Dirty in Cali
Googling sometimes helps guys. If you use honda-tech in the search string you'll find what your looking for.
Old Sep 11, 2012 | 08:21 AM
Former User's Avatar
Check whether 7.5A dash fuse 15 is blown. If so, click on the Fuse 15 TSB in my signature.
Old thread closed.
buls
Jun 12, 2013 03:27 AM
mudpuppy4life
Sep 10, 2011 04:40 PM
GRAVEDIGGER
Jul 30, 2002 12:01 AM
