Help me out on this engine
Old Jul 20, 2002 | 12:18 PM
slowman's Avatar
I took way too long
Default Help me out on this engine
Theres a D16A1 at my local junkyard. What is this out of and will it bolt up easily to a 90 Civic Si? Also, what are the specs?
Old Jul 20, 2002 | 12:33 PM
slowman's Avatar
I took way too long
Default Re: Help me out on this engine (90SIvic)
ok i know its 118hp. out of the old integras. can the head go on my D16A6 engine? ive heard that its hard but anyone got a link on how to do it or anything? i can get the whole engine for 200 bucks or less. thanks
EDIT: is it hard to just swap engines? does the clutch and everything hook up?
[Modified by 90SIvic, 4:13 PM 7/20/2002]
Old Jul 20, 2002 | 05:07 PM
slowman's Avatar
I took way too long
bump
Old Jul 20, 2002 | 05:58 PM
USDM 4G VTEC's Avatar
the D16A1 its a DOHC engine from the 86-87 integra.....
here are the specs..
D16A1
Displacement (cc): 1590
Power (bhp@rpm): 113 @ 6250
Torque (ft/lbs@rpm): 99 @ 5500
Compression Ratio: 9.3:1
Bore (mm): 75
Stroke (mm): 90
Cam Design: dohc
VTEC?: no
OBD: 0
Year(s) Produced: 1986-1987
In the following car(s): Acura Integra 86-87
it should bea bolt on.....
Old Jul 20, 2002 | 07:23 PM
slowman's Avatar
I took way too long
Default Re: Help me out on this engine (JDM EF9)
What should be a bolt on? The head or the entire engine? Also if not a bolt on, what is needed to complete this swap??
Old Jul 20, 2002 | 09:12 PM
Bgladfelter's Avatar
its also from the 88-89. Just diff config's.
Won't bolt into a 2nd gen CRX
Old Jul 20, 2002 | 09:39 PM
slowman's Avatar
I took way too long
Default Re: Help me out on this engine (Bgladfelter)
Ok. what about a 90 civic si?
Old Jul 20, 2002 | 09:44 PM
big pete's Avatar
same thing
Old Jul 20, 2002 | 09:50 PM
big pete's Avatar
Default Re: Help me out on this engine (big pete)
how much does the junkyard want for that motor?
Jsun25
Apr 18, 2017 05:29 PM
prelude_1
Feb 24, 2005 06:41 AM
in-n-outboy
Jul 28, 2004 12:03 PM
moparlulu
Aug 9, 2003 11:18 PM
MRVINCE1
Oct 28, 2001 09:31 AM
