90 accord clutch questions
Old Jul 16, 2008 | 03:52 PM
jbmcgee's Avatar
Default 90 accord clutch questions
My 1990 accord's clutch recently began losing pressure (tension) then would be fine but the other day I tried to drive somewhere and it will not go into gear when it is cranked (but will when not crunk) and the clutch has zero resistance. Ive never worked on a clutch before, the garage said $600 for a new one but I want to do everything possible myself to get down to the problem. The car has over 250,000 miles so $600 is out of the question, but if I can do what I can, with your help, I'll be happy knowing I tried. I read on one forum thread that I may need to bleed the line but I cant find the slave cylinder, found the master though. Any help is greatly appreciated.
Old Jul 16, 2008 | 04:21 PM
vapor40's Avatar
Default Re: 90 accord clutch questions (jbmcgee)
I would call another shop. Sounds like the master/slave to me. Is the master low on fluid? If it is then I think there is a tsb to replace the slave and master. Should not cost anywhere near $600 to repair
Old Jul 16, 2008 | 04:36 PM
jbmcgee's Avatar
Default Re: 90 accord clutch questions (vapor40)
thanks for replying, the master has fluid, beside the brake fluid reservoir, right? If not, how do I check master's fluid? I finally found the slave and it looks pretty old, not visibly damaged or anything but much older looking than the master.
Old Jul 16, 2008 | 04:52 PM
radiuslight's Avatar
you have to check it at the inside........under the dash........right at the end of the pedal
If theres fluid around the area its bad!
same thing happen to me!
Old Jul 16, 2008 | 05:21 PM
jbmcgee's Avatar
Default Re: 90 accord clutch questions (radiuslight)
I checked around the end of clutch from inside and there is fluid build up around the master cylinder. Would I be safe in just buying a new master and slave together and simply replace them. I guess I would have to flush the system? Thanks for the help.
Old Jul 17, 2008 | 09:51 AM
jbmcgee's Avatar
Could someone tell me how to replace the master/slave cylinders in a 90 honda accord, I found plenty of info on other things but not much on this. I have a Haynes manual and I can see the different pieces but it doesnt tell me exactly how to do the replacement, is it simply disconnecting hoses and "plugging" the new ones in? are there any steps that I may overlook having this be the 1st time to do this? Also, I found a set of master/slave cylinders on ebay for 1/2 the cost of any other autoparts sites, too good to be true? Thanks
Modified by jbmcgee at 5:10 PM 7/17/2008
Old Jul 18, 2008 | 01:17 AM
I dont trust that ebay stuff!
I'm gonna try the one from TAS...see what happens!
Old Jul 19, 2008 | 03:44 AM
breeziebabyyy's Avatar
Replacing the master is gunna be a bish, its time consuming! I would suggest going to cb7tuner.com to get a thread and read up on how to replace it also I would stop at your local autozone and pick up a haynes manual.. it does wonders !! Laterssss
-Keanna
Old Jul 23, 2008 | 01:19 PM
shutgun21's Avatar
what do u mean by no resistance in the pedal? does it stay up? (comes back up after u step on it?) press ur clutch pedal n have someone watch if ur slave cylinder pushing the fork at all. if its pushing the fork and u have no clutch ingagement could b ur clutch, if the fork wont move it could be ur slave cylinder
axelknight
Mar 22, 2018 05:46 PM
JusAccord
Nov 7, 2011 05:51 PM
ricerEJ8
Feb 23, 2008 04:04 PM
Problemo
Oct 13, 2005 01:12 PM
-Bionic-
Apr 23, 2004 05:46 AM
