anybody run 225/50/15 tires on their stock 4th gen Si / Vtec rims?
i had 225/50 15's on last time. They look nice on the car, and have a little more stick when cornering hard.
However i had very noticeably more sidewall deflection. made the car really spooky over 100. Could have been the crap Falken ZE512's tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 »</TD></TR><TR><TD CLASS="quote"> Could have been the crap Falken ZE512's tho
It was.....I have done 130mph down the front straight at GateWay and Gratten on my Toyo RA1s.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piggydog »</TD></TR><TR><TD CLASS="quote">wondering how it handles?</TD></TR></TABLE>
I did....but just fronts and they were Drag Radials.....
I also run 225/50/15s on Rota 15x6.5 and they are great....
</TD></TR></TABLE>It was.....I have done 130mph down the front straight at GateWay and Gratten on my Toyo RA1s.....
lol.. i looked at the pic and initally thought, yeah, another prelude on a track.. then i saw the right rear... very nice
that's on the RA1's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2IntegraGS »</TD></TR><TR><TD CLASS="quote">Nice pic. What about some 215/45/15s?</TD></TR></TABLE>
Idk who makes that size but my friend runs 225/45/15 Hoosiers on his race-car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 »</TD></TR><TR><TD CLASS="quote">lol.. i looked at the pic and initally thought, yeah, another prelude on a track.. then i saw the right rear... very nice that's on the RA1's?</TD></TR></TABLE>
Yep....entering the "BITCH" @ Hallett in tulsa, OK
Pretty rare to see a lowered Prelude lift a leg....and I do it with ease.
1.0G+ on R comps FTW!
225's look great, but depending on the tire the sidewall flex is just not worth it if you are into taking high speed corners.
I was running 225/45/16 BFG KDW2's on my stock wheels and the tires folded under stress which isn't exactly the greatest feeling while attacking interstate on/off ramps, lol.
I'm now running the same tires but on wheels that are 1" wider than stock and the sidewall strength improved 10x.
hey guys really appreaciate the input. One more question with the increases in gas did you noticed a drop in MPG?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piggydog »</TD></TR><TR><TD CLASS="quote">hey guys really appreaciate the input. One more question with the increases in gas did you noticed a drop in MPG?</TD></TR></TABLE>
Taller tires=lower revving=better mpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">225's look great, but depending on the tire the sidewall flex is just not worth it if you are into taking high speed corners.
.</TD></TR></TABLE>
With what kind of tire pressure?...Id bet that was more of an enemy than the sidewall. When I race, I can tell in a split second if my pressure if too low. I usually start on real hot days at 34psi and they will go to 44psi with heat. The 1st few laps are brutal and the car wiggles. On cooler days I start out at 40 and don't feel it. If you're trying to push tires to the limit at >40psi a 45/50+ will roll. To add you want a small amount of roll under full load turning to use every last bit of the tire.
.</TD></TR></TABLE>
yeah I think 205/55/15 and 225/50/15 are very similar diameter wise so RPMs should only be affected a tiny bit. 225 would have more contact so more rolling resistance and probably more weight.
piggydog
Jul 14, 2008 03:46 AM
Bucktown
Apr 7, 2004 10:47 AM
