NEED AUTO-2-MANUAL TECH HELP!!
Old Jul 16, 2008 | 11:08 AM
vgk414's Avatar
Default NEED AUTO-2-MANUAL TECH HELP!!
hey wassup HT!!!?!? i'm doing a little project on my 94 EG HB!
it's an Auto but have everything that needs to be converted into MANUAL!!!
i'm just wondering, i have a COMPLETE JDM D15B w/ TRANNY, WIRE HARNESS IN-TACT, AXLES, SHIFT LINKAGES, ECU!!! I also have the PEDAL ASSEMBLY, clutch master cylinder, and slave cylinder, but just need hardlines! Would there be any problems doing this kind of swap/conversion?!??! Would everything just plug n play????
<U>i took out everything that was automatic in the interrior console, and the motor.......any wiring i have to do???!</U> please help me out!!!! thanks i hope to hear from you all soon that's done this before!!!
Old Jul 16, 2008 | 11:51 AM
generation_D's Avatar
this is a marketplace not a tech support forum.
Old Jul 16, 2008 | 12:01 PM
VRD^sam's Avatar
Default Re: (generation_D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by generation_D &raquo;</TD></TR><TR><TD CLASS="quote">this is a marketplace not a tech support forum.</TD></TR></TABLE>
x2
Your a member from 05 you should atleast know how to use the search button This has been covered many many many times.
Old Jul 16, 2008 | 05:35 PM
ef9_frosty's Avatar
Default Re: (VRD^sam)
no, not much wiring just to hook up the clutch safety switch, make sure u keep the male plug from the auto shifter to use..... if u need more help or info pm' me
Old Jul 16, 2008 | 09:32 PM
vgk414's Avatar
Default Re: (ef9_frosty)
thanks!! i'll hit u up if anything goes wrong!!!
Old Jul 16, 2008 | 09:41 PM
pooorman's type-r's Avatar
Default Re: NEED AUTO-2-MANUAL TECH HELP!! (vgk414)
don't forget about the auto-to-manual tranny mount!
Old Jul 21, 2008 | 04:38 PM
vgk414's Avatar
Default Re: NEED AUTO-2-MANUAL TECH HELP!! (pooorman's type-r)
thanks for the info. but i already have that covered......it's just the necessity of wiring, that's all........
red02s2k
Apr 18, 2008 05:57 PM
jaykav99
Audio / Security / Video
Jun 18, 2006 02:40 PM
GSR_ITM
Mar 28, 2006 06:52 PM
JswineyHB93
Jul 19, 2004 09:38 PM
