96 Passport Question
My Dad is trying to sell his damn 96 Passport and the damn starter is screwed up and I can't even find the damn starter to get it rebuilt or fixed.
So does anyone have a diagram or manual that shows this location?? Any help would be greatly appreciated.
1) Disconnect negative batt cable.
2) Raise the vehicle
3) If you have a skid plate, remove it
4) on the 3.2L engine A) disconnect the heated o2 sensor connectors from exhaust pipe. B) Unbolt the front exhaust pipes from the manifolds, unbolt the front exhaust crossover pipe from the cat converter flange.
C) Seperate the front exhaust crossover pipes from the ehaust manifold then slide it to the rear of the car.
5) Remove the starter heat shield if there is one.
6) Label and disconnect the wiring connectors.
Don't forget the shims.
BigFiasco
14
Jul 24, 2008 11:31 AM
