Cutting Out.
Old Jul 16, 2008 | 05:48 AM
DenzComp's Avatar
Default Cutting Out.
I've had my '91 hatch off the road for a while. I just recently put it back on, and am having a weird problem.
At certain speed it will just cut out, and buck for a split second. The car remains running, but it is comparable to a human hiccup.
It's starting to do it in first gear now too...I'll take off and it'll hiccup...then chirp the tires...
It's really annoying. The car has never died on me, but based on how it is acting, I'd like to get this figured out.
I did a MPFI conversion about a year ago, so I'm not sure if that is acting up or not...
Just figured I'd see if anyone has any input and/or advice.
Thanks in advance,
-Dennis
Old Jul 16, 2008 | 07:33 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Cutting Out. (DenzComp)
is your ecu throwing any codes? is your battery loose or anything like that? if you arent throwing any codes, maybe you should check wheel bearings too, just to be safe. If one of them is in rough shape, it could cause that.
do your revs drop or electrical cut out when it happens?
anyway.. there are a lot of things it could be, so any more info you can provide about the symptoms, the easier it will be to figure out.
Old Jul 17, 2008 | 05:18 PM
DenzComp's Avatar
I have no tach, but the revs don't really seem to drop. It does chirp the tires though in first..so it must drop a little..then kick back in...
As far as ECU...I'm getting IAT and IAC (EACV).
Probably one of those?
fuzzysig
Acura TL, RL & ZDX
Oct 18, 2016 01:41 PM
mmab18c
Oct 19, 2008 07:58 PM
lovin'my type-s
Aug 13, 2007 07:43 PM
esdafoo
Mar 11, 2007 07:59 PM
CBEEF80
Nov 11, 2003 11:38 AM
