clay bar with Degreaser??
Old Jul 16, 2008 | 02:56 AM
90goldhatch's Avatar
Default clay bar with Degreaser??
is it bad to use degreaser for example simple green or purple power on your paint, because when i bought the clay bar kit and tried the spray that it came with it didnt take off the heavy over spray from the previous owner so i used degreaser with the clay bar is that bad.
Old Jul 16, 2008 | 09:00 AM
GuNnErGoD's Avatar
Default Re: clay bar with Degreaser?? (90goldhatch)
A degreaser isn't going to do anything to overspray. You're going to want to use combination of a stronger (red) clay and lacquer thinner if blue clay isn't working. The red clay is going to scratch the paint pretty bad because it's similar to running sandpaper over the paint therefore you must buff it.
To technically answer your question: No, degreaser will not hurt your paint if you wash it off fairly soon after you apply it. Also, the spray they give you with the clay bar isn't designed to do anything other than provide lubrication for the clay bar.
In summary, the only thing that is going to help you remove the overspray is blue/red clay, lacquer thinner on a rag, and buffing in that order.
Good luck!
Old Jul 16, 2008 | 04:00 PM
Default Re: clay bar with Degreaser?? (GuNnErGoD)
actually the degreaser did take off the over spray fast and easy, but thanks for the reply though i just wanted to make sure i wasnt hurting my paint
Old Jul 17, 2008 | 07:45 AM
GuNnErGoD's Avatar
It wasn't overspray then. Probably tar.
Old Jul 17, 2008 | 07:12 PM
no it was over spray because it was around the molding all the way around the car
Old Jul 23, 2008 | 12:37 PM
noodlez1390's Avatar
it wasent overspary den overspray dosent *** off dat easy u got buff or claybar
Old Jul 23, 2008 | 02:05 PM
RoadRage212's Avatar
Guys he said he used the CLAY BAR WITH DEGREASER!!!
It won't HURT the paint to use a clay bar with degreaser, but next time you can just use a cap-full of degreaser with water in a spray bottle and do just fine. Just enough to break the surface tension of the water will work.
Old Jul 23, 2008 | 02:15 PM
Default Re: clay bar with Degreaser?? (noodlez1390)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noodlez1390 &raquo;</TD></TR><TR><TD CLASS="quote">it wasent overspary den overspray dosent *** off dat easy u got buff or claybar</TD></TR></TABLE>
ok i guess it was just left over poop from monkeys throwing it back in the jungle when my car was used to off road back in the days
ummm yeah i used CLAY BAR WITH DEGREASER like roadrage said, the overspray came off just that easy with purple power you should try it
for the record one more time it was (OVERSPRAY) from the previous owner trying to paint the moldings and it looked like he never masked off anything, probably just took paper and went as he painted
Modified by 90goldhatch at 3:22 PM 7/23/2008
Old Jul 23, 2008 | 02:38 PM
ow ok wit degresser my bad yea i work at a bodyshop u culda just used window cleaner and da bar
Old Jul 23, 2008 | 05:55 PM
window cleaner? nice ill try that, i think the degreaser is eating up my clay bar
Old Jul 24, 2008 | 04:00 AM
yeah degreaser makes paint look like $hIt
heyimrchills
Paint and Body
Oct 16, 2009 06:38 PM
CARMA_626
Detailing
Nov 26, 2008 12:26 AM
i hate my team
May 4, 2003 11:19 AM
SlowB16
Feb 17, 2002 10:47 PM
Integra187
Oct 2, 2001 03:39 PM
