ls/vtec build should i use a thicker oil?
Old Jul 15, 2008 | 06:58 PM
si90rex's Avatar
Default ls/vtec build should i use a thicker oil?
hoping for 10,500 rpms red line itr os, sk2 pro 3 cams, balanced bottom, p&p b16 head and itb's. will 5-w30 be fine or what any suggestions?
thanks for any help
Old Jul 15, 2008 | 07:23 PM
92integraVTECgsr's Avatar
Default Re: ls/vtec build should i use a thicker oil? (si90rex)
5w-30 will be fine.
I use 10w-30 in my LS/VTEC.
Old Jul 15, 2008 | 08:13 PM
stealth50k's Avatar
10-30 is what i use also. 5-30 is ok but i would use 10-30 since your revin it pretty high
Old Jul 16, 2008 | 07:53 AM
si90rex's Avatar
Default Re: (stealth50k)
THANKS GUYS
Old Jul 16, 2008 | 08:24 AM
00MRSi's Avatar
Default Re: (si90rex)
10.5k rpm? What's the point of revving that high?
Old Jul 16, 2008 | 08:53 PM
ToeJam's Avatar
Default Re: (00MRSi)
maybe his vtec is set at 7k and he NEEDS to rev it high to get the most out of vtak?
Old Jul 16, 2008 | 09:07 PM
jdong's Avatar
on my LSV rex i use 10w30 runs pretty good.
boostedblkef
Mar 2, 2006 10:34 PM
88whitehf
May 26, 2004 11:21 PM
Thrashin
Apr 1, 2003 04:39 PM
Stop the Beast
Dec 8, 2002 03:53 PM
Lookincrazy
Jul 18, 2002 09:51 AM
