EF/ED rear brake swap INFO
Old Jul 20, 2002 | 08:47 AM
Pissoff's Avatar
Default EF/ED rear brake swap INFO
4G HATCHES NEED:
90-91 CRX REAR TRAILING ARMS, 90-91 CRX rear brake lines, 90-93 TEG 2dr Ebrake cables
OR
90-93 TEG REAR TRAILING ARMS, 90-93 TEG rear brake lines, 90-93 TEG 2dr Ebrake cables
OR any combo of the 2
2G CRX NEED
90-91 CRX REAR TRAILING ARMS, 90-91 CRX rear brake lines, 90-91 CRX Ebrake cables
OR
90-93 TEG REAR TRAILING ARMS, 90-93 TEG rear break lines, 90-91 CRX Ebrake cables
4DR ED's need:
OR
90-93 TEG REAR TRAILING ARMS, 90-93 TEG rear break lines, 90-93 TEG 2dr Ebrake cables
MASTER CYLINDER INFO
DX: 13/16
HF: 13/16
SI: 7/8
EX: 15/16
use booster that comes w MC
IF U WANT TO USE TEG 15/16
you also need the booster
THE PROP VALVE:
you can use it it helps alittle NOT NECESSAARY
USE CRX 90-91 SI
OR 90-93 TEG NON ABS
MY REAR
MY FRONT
i personally have teg 15/16 and booster w SS lines
FRONT: ITR calipers in front w 11.1 prelude rotors on EX knuckles
REAR: STOCK REAR ARMS w/ 1 90-93 teg rear disk hub spindle caliper and rotor
and 1 91 SIR CRX rear disk hub spindle caliper and rotor
[Modified by Usdm ED9, 5:50 PM 7/20/2002]
[Modified by Usdm ED9, 5:55 PM 7/20/2002]
[Modified by Usdm ED9, 1:07 AM 7/21/2002]
Old Jul 20, 2002 | 08:51 AM
BoostedED9's Avatar
Default Re: EF/ED rear brake swap INFO (Usdm ED9)
what did you need to do to put on those front brakes????? my friend put on a master cylinder from a 87 accord hatch thing, you know the info on that one???
Old Jul 20, 2002 | 08:54 AM
Pissoff's Avatar
Default Re: EF/ED rear brake swap INFO (ED9Hybrid)
Old Jul 20, 2002 | 09:21 AM
BoostedED9's Avatar
is there any other caliper that can be used or does it have to be itr?? any special brackets???
Old Jul 20, 2002 | 09:24 AM
Pissoff's Avatar
ITR or accord wagon
remember u NEED EX knuckles to make it work
Old Jul 20, 2002 | 09:31 AM
BoostedED9's Avatar
ok so 90-91 civic ex knuckle owuld be the one i should pick up.... and hwat year rotors??
Old Jul 20, 2002 | 09:33 AM
Pissoff's Avatar
11.1 inch redrilled prelude rotors available @
www.fastbrakes.com
Old Jul 20, 2002 | 10:59 AM
rice_classic's Avatar
My crx and my old civic hatch Si BOTH had 13/16 MC's not 7/8ths.. just an FYI
Old Jul 20, 2002 | 11:09 AM
Pissoff's Avatar
Default Re: EF/ED rear brake swap INFO (rice_classic)
yeah if u had 88's
Old Jul 20, 2002 | 04:01 PM
EF'n Fast's Avatar
88-89 and 90-91 have different bolt patterns for the master cylinder to booster.
[Modified by EF'n Fast, 1:03 AM 7/21/2002]
jaypain
Apr 9, 2009 08:47 PM
gutted-dx
Jul 28, 2004 09:55 AM
Ckleijne
Apr 20, 2004 10:45 PM
buckNasty
Jan 7, 2004 08:45 AM
Cereal_Killer
13
Sep 22, 2001 06:16 PM
