smoke problems please help me out
thats coolant then, which means a blown head gasket. check to see if any coolant has got into your oil, which would cause it to look like a chocolate milkshake kinda color. Or the oil may have got into your cooling system. in which case you will find crud in the radiator filler neck, and usually on the bottom of the radiator cap
i check the oil and is fine .. went i the car in idle i rev the car in good temperature and alot smoke came out from the exhaust ? i just buy head gasket kit on ebay i hope will solve the problem
Layziebtnh055
Apr 15, 2004 06:07 PM
