Do I need to use these rear engine mounts.
Old Jul 15, 2008 | 08:26 AM
89civichb's Avatar
Default Do I need to use these rear engine mounts.
When I reinstalled my engine I did not use # 9 and # 10. Are they necessary? Or will I be ok not using them.
Thanks
Old Jul 15, 2008 | 08:41 AM
Furyof4's Avatar
Default Re: Do I need to use these rear engine mounts. (89civichb)
Are you serious?
First of all, you will either have #9 or #10 not both. That diagram shows parts for auto and manual trans.
YES you need it!
Old Jul 15, 2008 | 08:45 AM
89civichb's Avatar
Ok well could you please tell me where it goes exactly.
Old Jul 15, 2008 | 08:59 AM
Furyof4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civichb &raquo;</TD></TR><TR><TD CLASS="quote">Ok well could you please tell me where it goes exactly.</TD></TR></TABLE>
The same place you removed it from.
Its pretty self explanatory really. Go look at your car. You'll see 3 threaded holes on the trans/block and one though the rear mount. Connect the dots...
Old Jul 15, 2008 | 09:00 AM
thisiskev's Avatar
its your motor mount. it connects the rear part of the engine/tranny to the chassis. kinda a major part.
Old Jul 15, 2008 | 09:22 AM
97grnrs's Avatar
Default Re: Do I need to use these rear engine mounts. (thisiskev)
without that u will break the other mounts and motor will eventually sag and fall. and u will strip out any good mount bolt holes. u need that on. and best to use the front one too if u can.
Old Jul 15, 2008 | 09:55 AM
89civichb's Avatar
Default Re: Do I need to use these rear engine mounts. (97grnrs)
Well the engine is bolted to the #5 mount but I had the engine out for a while and cant remember where #9 went. I mean the engine is in and it seems its ok but i dont want to start driving it and something go wrong!
Old Jul 15, 2008 | 09:56 AM
EvanFullwood's Avatar
they make motor mounts for a reason....its not there "to use if you want to"..........
Old Jul 15, 2008 | 10:38 AM
89civichb's Avatar
Does anyone have a picture of where it goes exactly. Sorry for being such a noob.
Old Jul 15, 2008 | 11:01 AM
palisoc05's Avatar
how does the #5 mount bolt to the motor w/o the use of the #9 bracket? if this is the mount/bracket that im thinking of, #9 bolts to the motor and the bolts through the #5 mount
Old Jul 15, 2008 | 12:44 PM
89civichb's Avatar
OK like I stated the engine is bolted to the #5 mount. Isnt #9 a stabilizer. Ive searched quite a bit and can't figure out how it mounts. I've been at work all day and was just wondering if anyone could post a picture. Its been a while since I took the engine out so my memory doesnt recall how it was mounted. The diagram is not very helpful.
Old Jul 15, 2008 | 09:50 PM
thisiskev's Avatar
you have the picture. its pretty simple. #9 connects to #5 and your engine and tranny.
Old Jul 16, 2008 | 07:09 AM
p10hlm's Avatar
Old Jul 16, 2008 | 09:44 AM
gsrpedro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civichb &raquo;</TD></TR><TR><TD CLASS="quote">OK like I stated the engine is bolted to the #5 mount. Isnt #9 a stabilizer. Ive searched quite a bit and can't figure out how it mounts. I've been at work all day and was just wondering if anyone could post a picture. Its been a while since I took the engine out so my memory doesnt recall how it was mounted. The diagram is not very helpful. </TD></TR></TABLE> well u have a b seriees or d series motor??
BIGef
Mar 15, 2012 12:38 AM
egtony
May 27, 2009 08:26 AM
B18CYAAA
Jul 12, 2007 05:11 PM
ABK
Dec 24, 2004 07:57 PM
KevronsEG
Apr 30, 2003 09:48 AM
