DA RTA Question Hub/bearing??
Old Jul 14, 2008 | 10:01 PM
TheSauceSpot's Avatar
Default DA RTA Hub/bearing on CRX Si ??Need some help...
I purchased DA(it was stamped onto the arms) RTA from a local junkyard. I want to replace the hub/bearing and the rear dust shields b/c there mangled so i ordered them through Acura. The parts they gave me have ABS sensors on the hubs(42200-sk7-a01) and holes through the dust shields(43253-sk7-950) for ABS line im assuming. I plan to go back to Acura for the right part but im trying to find the right part numbers before i go back... ive searched the Acura Oem parts sites and cant seem to find the right rear hubs or dust shields(w/out ABS)..... Im not 100% positive what year and model rear trailing arm it is, all i know is that it had a white DA stamp on it and the hubs i removed dont have ABS nor do the dust shields. Any help or direction to look in for the right part number for the hub/bearing and shields is appreciated very much.
ANYONE HAVE THE PART NUMBER FOR A DA REAR HUB?BEARING W/OUT ABS?????????
What different RTA and Brake set-ups came on DA integras?(LS, GS, GS-R)
Whats the size difference of a 91Crx Si rear brake set-up to a DA set-up?
Modified by HOTSAUCE01 at 6:24 AM 7/15/2008
hondatuner020
Oct 21, 2014 09:39 AM
Nisif
May 28, 2008 07:43 PM
6SPD_EK
Aug 7, 2007 12:50 PM
Bignasty
Aug 23, 2004 08:53 AM
