1988 Ford Mustang 5.0 H.O. convertible
Hey guys, posting this up for sale for my girlfriend since it is technically her car.
The rundown:
1988 Ford Mustang convertible
Candy apple red with white top and black trim
Gray leather interior
5 speed manual
5.0 H.O. V8
~ 90,000 miles
A little history - my girlfriend bought the car 2 years ago in June. It was driven until she went off to school in August and stored for the winter. It was then brought back out in April and driven again until October when she changed schools, then put away until April again. So far we've put about 9,000 miles on the car from when it was purchased. It doesn't get driven a lot since it's pretty much a "nice day only" car and is kept very clean. It's been well taken care of in the time she's owned it. I've been keeping it in great running shape and have been performing some maintainance over the course of the past year. I've put together a list of everything that's in the car and that's been done to it. The list pretty much tells you everything you need to know about the car and should answer all the questions you may have. The car was cleaned up very thoroughly and the pictures show were taken a few hours ago. And now onto the list and pictures:
Engine
Full engine detail job
Averages between 20-22 MPG on 89 Ethanol octane
No misses, knocks, or pings
Ford Racing F series camshaft
K&N oil filter (recent)
Mobil 1 5W30 Clean 5000 oil (recent)
Cooling system flushed and refilled with Polar coolant (recent)
Fuel system cleaned with Seafoam liquid (ran through gas tank and injectors)
Newer fuel lines
New Motorcraft fuel filter
Inline fuel pressure gauge
Walboro 255 LPH fuel pump
Intake system cleaned with Seafoam spray (sprayed through throttle body and MAF)
K&N OEM style air filter (newly cleaned)
BBK 65mm throttle body
5.0 Cobra upper intake manifold
5.0 Cobra lower intake manifold
Ford Racing headers
2.5” dual H-pipe exhaust with dual mufflers
Crane Cams ignition coil
Crane Cams ignition box (mounted near passenger foot rest)
MAF voltage adjuster (mounted on passenger inner fender)
Ford Motorsport spark plug wires
Autolite spark plugs
Battery cables cleaned and coated with di-electric grease
Autocraft battery terminals (coated with di-electric grease)
Motorcraft Silver Group 65 (850 CCA) battery (newly charged and terminals cleaned)
Armor Mark serpentine belt
Valve covers painted to match body color
No fluid leaks in engine bay
Brakes
Mustang SVO front caliper conversion
Mustang GT/LX 5.0 front rotor conversion
Front brakes overhauled (new pads, new rotors, all parts lubed, rust removed)
Russell front stainless steel braided brake lines
Front brake line-locker setup (remote activated)
87-88 Ford Thunderbird Turbocoupe rear disc brake conversion
Rear brakes overhauled (new pads, machined rotors, all parts lubed, rust removed)
Russell rear stainless steel braided brake lines
Willwood rear disc brake proportioning valve
Newer brake lines
Brake system bled and refilled with DOT 4 brake fluid
Suspension and handling
Centerline Scorpion 16” 4 lug billet rims
Hankook Radial K106 tires (front 8/32”, rear 10/32”, and newly balanced)
Energy Suspension rear lower control arms
New OEM rear track bar bushings
BBK springs (front and rear)
Monroe Formula 1 front shocks
Newer OEM Mustang GT rear shocks
Custom front camber/caster plates
Aftermarket rear sway bar
Aftermarket rear panhard bar
Aftermarket full length subframe connectors
Wheel bearings, tie rod ends, and ball joints have no play in them and no grease leaks
Power steering system drained and refilled with ATF +4
Front wheel bearings cleaned and re-packed with Mopar wheel bearing grease
Recent alignment
Drivetrain
Lucas synthetic 85W90 differential fluid
Positive traction 8.8” rear differential (3.73 gearing, sealed with Permatex Red RTV)
Custom driveshaft loop built into crossmember
Redline D4 ATF in transmission
Transmission shifts smoothly with no grinding
Pro-5 short shifter
New clutch plate
New clutch friction disc
New throwout bearing
New pilot bearing
Recent clutch adjustment
Body
Full body, trim, top, light and lense, and wheel detail job
Candy apple red paint job (recent)
Ford Mustang Saleen body kit (front bumper, rear bumper, side skirts, spoiler)
Cervini’s ram-air style fiberglass hood
“302” fender badges
Sylvania SilverStar ULTRA headlight bulbs
All turn signals, license plate lights, brake lights, and reverse lights work correctly
Rain-X wiper blades
Hood latch, electronic trunk latch, and electronic fuel door latch all work correctly
Convertible top latches and actuates correctly with no binding and no leaks
Latemodel Restoration metal driver and passenger door handles (bolted in)
Door locks, hinges, and latches lubed with white lithium grease
No fluid leaks on underbody
Interior
Full carpet, window, seat, door, and dashboard detail job
Grant GT gray and black steering wheel
White faced gauges
Fully adjustable driver and passenger seat with power lumbar
Power front and rear windows
All window tracks and window regulators greased and work correctly
All power window switches function correctly
Chrome window switch bezels
Power door locks
Power door lock actuators greased and work correctly
All power door lock switches function correctly
Ford Mustang Saleen light bar
Kenwood CD receiver
Boston 5.25” component door speakers
Boston ¾ “ component tweeters (mounted behind headrests on subwoofer boxes)
Boston speaker and tweeter crossovers (mounted underneath passenger seat)
Rockford Punch 1” tweeters with crossovers (mounted in dash)
Speakers powered by Rockford 2600x Series 1 amp
Kicker 10” subwoofers (mounted in custom sub boxes by rear seat)
Subwoofers powered by Rockford Punch 100 DSM amp
Shortband AFR A-pillar gauge
All gauges work properly
Chrome pedal covers
That should cover about everything. Current price is $6,000 OBO with that being a starting price and working from there. This car does get a lot of attention at shows and can easily be used as a daily driver or weekend car. Due to the suspension tuning it is a little tight, but allows the car to be able to run through the twisties and at the 1/4 mile track. Also, the car is modified and is 20 years old, so it will have the slight squeeks and such, so please don't expect a perfect show car. There's also the option to further tune the car since the aftermarket is very large for these vehicles. If you need any more information or other pictures feel free to PM me or send an e-mail to templeton_cody@hotmail.com or you can reach me at 563-590-5687 (leave a message if I do not answer). Thank you for looking.
The rundown:
5 speed manual
5.0 H.O. V8
~ 90,000 miles
Engine
Newer fuel lines
Ford Racing headers
Brakes
Newer brake lines
Recent alignment
Drivetrain
Pro-5 short shifter
New clutch plate
New pilot bearing
Body
“302” fender badges
Rain-X wiper blades
Interior
White faced gauges
Power door locks
Kenwood CD receiver
Chrome pedal covers
Rzoops
Oct 4, 2010 05:36 PM
Rzoops
Southeast (Sales)
Oct 4, 2010 05:07 PM
Rzoops
Oct 4, 2010 05:06 PM
