EF engine problem
Old Jul 14, 2008 | 05:18 PM
tennisboy's Avatar
Default EF engine problem
I've recently had a problem with my 1990 honda civic dx...hope u guys can help me out.
Sometimes when I try to start up the car it just won't start until after the 20th try. Also, while i was driving on the road the engine seemed to have stopped and the car would gradually slow down forcing me to drive to the side of the road. Once again, when i try to start it up it won't until about the 10th attempt. While i was on the side of the road with the hood up a guy who claims to be a mechanic parked behind me and thinks that it's my distributor. I'd like your guys' expertise on this, could it be just the distributor i need to change or other things too?
Old Jul 26, 2008 | 08:06 PM
beige89civic's Avatar
* B A N N E D *
Default Re: EF engine problem (tennisboy)
Check for ecu codes. Turn key on and count led flashes. the ecu is on the passenger floor board. If you didn't know already
Old Jul 27, 2008 | 01:37 AM
$C-BRAM$'s Avatar
my 91 dx did the same. it started flashing code 4 which is crankshaft position sensor. i swapped dizzys and it still did it so i swapped ecus and it still did it. i ended up having to redo connector c going to ecu
Old Jul 27, 2008 | 07:05 AM
IndySporty's Avatar
Default Re: EF engine problem ($C-BRAM$)
It also would not hurt to replace the Main Fuel Relay with a known good one. It's right behind the change purse in your dash by the driver's door. Kind of above the hood release. That symptom could possibly be caused by this, but it usually will not make the car cut off while driving... either way it's cheap insurance a brand new one is like 50 bucks.
MarsEf9
May 25, 2010 12:08 PM
hondamagna84
Nov 2, 2009 05:30 PM
CRX30436
Jul 30, 2008 08:03 AM
detailer67
Apr 22, 2004 08:10 PM
Tariqasi
Jul 29, 2003 05:09 PM
