are all f22 distributors the same
i am putting a f22b1 vtec in my car will a f22 non vtec distributor work. The vtec distributor wiring is only 5 wire and a 4 wire crank sensor. where my old motor did not have the crank sensor
there's internal coil and external coil... you need to find out which one is yours.
In my case, f22b1 (obd2).... the coil was internal. I believe that f22b2's are external... but... they're not all the same.
its a 95 civic and the engine is a 97 accord. i have a h22 that i am building so i just needed a engine to get the car running so i could drive it. when i did the h22 swap i pulled the guts out and put in my civic guts. but i cant seem to do this on the f22. I am going to run a p28 with f22 vtec base map. the f22 engine has a crank sensor that my guess that is why only the 5 wire dizzy. could i wire that crank sensor up on my obd 1 ecu
downNoutCD5
Feb 22, 2013 03:17 PM
jbonehead85
Dec 8, 2004 04:01 PM
