Couple thinks before Turbo. . . . ?
Old Jul 20, 2002 | 01:22 AM
WykidEH's Avatar
Default Couple things before Turbo. . . . ?
I have a few questions about a couple things before I put the Turbo on. . .
First, I want to run better valve springs and retainers. . . . whitch one do you all recommend?
Second, what pistons for 9.3:1c/r? In a B18C. . . . .
Thanks in advance,
Jeramy
[Modified by WykidEG, 4:25 AM 7/20/2002]
Old Jul 20, 2002 | 06:27 PM
GTM's Avatar
GTM
Default Re: Couple things before Turbo. . . . ? (WykidEG)
We usually use Crower, Ferrea, or Web Cam valetrain products in our buildups. They are "tried and true."
As fr a 9.3:1 compression ratio, good luck. You're going to have to probably used forged aftermarket pistons rated around 9.0:1 and play with your combustion chamber volume (i.e. by milling the head or using a different thickness head gasket) in order to achieve a perfect 9.3:1 CR. By the way, why 9.3:1?
Old Jul 20, 2002 | 07:09 PM
WykidEH's Avatar
Default Re: Couple things before Turbo. . . . ? (GTM)
using the Endyn pistons in a B18C nets 9.3:1. . . . . how much for the Web valvetrain?
Old Jul 20, 2002 | 07:12 PM
Kamin's Avatar
just a suggestion
if your gonna replace the pistons
might as well do rods too.
then you can run even more boost
**** while were at it. get the block sleeved OR a blockguard welded in.
the roller coaster of debt begins.
Old Jul 21, 2002 | 03:40 PM
WykidEH's Avatar
Default Re: Couple things before Turbo. . . . ? (KAMiN)
I already have GE sleeved block and Eagle rods, I just don't know what pistons and valvetrain parts to run?
Jeramy
honda_guy58
Feb 4, 2009 09:01 PM
Dj Skidz7
Dec 19, 2006 12:00 AM
elementmilwaukee
May 5, 2004 10:14 PM
Turbo-4dr-GSR
May 1, 2003 10:33 PM
AllMotorITR
Jan 13, 2002 12:41 AM
