Roof Swap on a ef
Old Jul 13, 2008 | 10:54 PM
4DRmafia's Avatar
Default Roof Swap on a ef
Long story short. I smashed into a cow. Cow's head damaged my roof. I read up wes v write up how to do it and everything. With me little experience into body work and everything, I managed to get the roof off nicely. My question is do I spot weld the roof on and then use some type of glue or glue it down and then spot weld around it? I just want to do it right at the 1st time.
here some pictures of the damage and during the process.
here when i had some fun with a friggin cow.
still got them hairs on there! Yum tasty!
It been sitting an year after the wreck, because I couldnt find a si shell. Car is striped as of now, Because I figure to do a complete overhaul with shaving engine bay and tucking and everything else at once.
donor car and roof.
I got it just sittin on the project car, nee to know what to do 1st.
Old Jul 13, 2008 | 11:45 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: Roof Swap on a ef (4DRmafia)
Nice
Cant wait to see the finished product.
Old Jul 14, 2008 | 12:20 AM
4DRmafia's Avatar
Default Re: Roof Swap on a ef (PhantoM.DA)
yeah wont be too long now. just want to get the roof done and finish up the engine bay and then swap everything back in. All oem stock motor/tranny and everything else for now until money grows.
Old Jul 15, 2008 | 06:42 PM
Disease's Avatar
Unless it came with panel bond then I would not bother with it. Just fit it up and clean your weld holes and the panel you are welding onto. Use a weld through primer on the car and then go at it. After it is all weldid on, clean all your welds front and back, do your body work and use some vari prime or an acid etch primer on any bare metal or welds. After everything is all primed then run a thin bead of sealer on any seams to prevent water leaks.
There you are done till you go to paint.
Old Jul 15, 2008 | 06:45 PM
Disease's Avatar
Default Re: Roof Swap on a ef (Disease)
I don't remember hitting the email button.
Old Jul 15, 2008 | 08:37 PM
kiddcarbuff's Avatar
yeah do jsut as disease said, i did this with an 88 dx civic. i swapped an Si roof onto it, not hard, jsut time consuming.
Old Jul 16, 2008 | 12:00 AM
BrownDx's Avatar
Default Re: (kiddcarbuff)
I need to do that.
Some homo ran up my hood across my roof.
Old Jul 18, 2008 | 12:49 PM
HybridKOOP's Avatar
Default Re: (BrownDx)
Did the cow die?
Old Jul 18, 2008 | 01:44 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">Did the cow die?</TD></TR></TABLE>
.. You think?
Old Jul 19, 2008 | 01:20 PM
bananaketchup's Avatar
hahahahaha man when i first saw b4 reading thought it was human hair but yea nice work
Old Jul 19, 2008 | 04:46 PM
Jason-'s Avatar
When you going to get it welded on and get this thing rolling??
-Jason
Old Jul 20, 2008 | 01:11 PM
4DRmafia's Avatar
sorry i havent update it lately. I was told by a pro bod y shop in the area to use panel bonding since its only a roof skin. It's done and the roof will not come off! glue is soo strong. About the cow, well it died because the pillar split his neck open.
Old Jul 20, 2008 | 02:45 PM
hondatunedbboy's Avatar
lol geezus
Old Jul 21, 2008 | 07:10 PM
mike9571's Avatar
Default Re: (4DRmafia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRmafia &raquo;</TD></TR><TR><TD CLASS="quote">sorry i havent update it lately. I was told by a pro bod y shop in the area to use panel bonding since its only a roof skin. It's done and the roof will not come off! glue is soo strong. About the cow, well it died because the pillar split his neck open. </TD></TR></TABLE>
Yup panel bond is the way to go. Im only familiar with 3M products, but the panel bond is stronger than a weld!
Good work BTW. At first I was honestly expecting a hack job.
Old Nov 30, 2008 | 11:46 AM
Endemic's Avatar
YashR1
May 30, 2016 10:42 AM
joshii_honda
Jan 27, 2015 04:54 PM
WELZ
Appearance Build Threads
100
Jun 8, 2013 10:33 AM
4DRmafia
Jul 15, 2008 10:26 PM
thapimpfromchi
May 31, 2007 05:58 AM
