To much compression?
Old Jul 13, 2008 | 10:34 PM
Mikes2000civicsi's Avatar
Default To much compression?
hey guys,i got flat faced valves and a head thats been milled,i was thinking of picking up 12:1 pistons,you think itll be to high?what do you think the final compression will be,think the heads been milled .02,thanks
Old Jul 13, 2008 | 11:16 PM
AllMTRWH0R3's Avatar
Default Re: To much compression? (Mikes2000civicsi)
This all depends on alot of other factors. Given the info you have provided you should be fine. Granted you get it tuned by a good tuner. Your in the EC so your likely to find a good one easily. Again, I won't E-thug the thread with random things "well this guy's cousin, brother baby momma had a cousin who did XYZ, I base them on facts. I've seen motors with the same compression your stating and make decent numbers.
Good luck on your build.
Old Jul 14, 2008 | 05:01 AM
Default Re: To much compression? (AllMTRWH0R3)
well what does it bump it up by with those 2? maybe .5?
SantaAnaFerio
11
Dec 15, 2009 03:06 PM
kornerk12
Jul 18, 2006 05:17 PM
zoom545
Nov 22, 2005 09:04 AM
-KangaRod-
Oct 14, 2003 05:18 PM
K20 EG
Jun 17, 2003 11:26 AM
