Installing Cruise Control
Old Jul 13, 2008 | 08:35 PM
Techy's Avatar
Default Installing Cruise Control
I probably won't wind up doing it myself but I'm going to attempt to install cruise control on B16A2 Swapped 96 Civic CX. I managed to come across a cruise control unit and switches for 96-00 Civics and figured why not.
I would like to know everything necessary for installing the Cruise Control. As I said, I have the unit and switches. I missing all the wiring however. I do have a wrecked 95 Civic EX Coupe that still has all that cruise stuff in it and I figured maybe I could use the wiring from it. If the plugs are different, well, I'm pretty good a rigging wiring so that's not too much of a problem.
So if someone could tell me everything necessary to install it and, heck maybe even some instructions on installing it if it's easy enough, that'd be great. Thank you for any help.
Old Jul 14, 2008 | 09:20 AM
Techy's Avatar
bump
Old Jul 14, 2008 | 10:42 AM
IanB's Avatar
I believe the cruise control for '96-'98 was vacuum, and the '99-'00 was electronic controlled, not sure if theres' any reason you can't install either setup on any year car though.
Download the service manual for whatever year you got the cruise control from, and it should have all the info you need to get it installed and working.
Snailor Built
12
Mar 12, 2015 03:06 PM
shotenITR
Apr 25, 2008 10:38 AM
1990crxsir
Honda Fit
Jan 25, 2008 06:14 AM
95lscivic
Apr 8, 2007 02:24 PM
hspoon
Jan 21, 2007 11:02 AM
