Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Noise from passenger's side fender area
Old Jul 13, 2008 | 08:30 PM
benitom's Avatar
Default Noise from passenger's side fender area
I am posting this to help out my friend.
http://www.youtube.com/watch?v=3fk3bEYm0Es
My friend owns an 07 civic ex 4 door with about 15K miles
Pls take a look at the link above and you will clearly hear the metals hitting sound coming out from the passenger's side fender area. He has not removed anything from that area and everything in his car is stock. This noise starts to come up when he drives around 70mph and very noticeable when a cross wind blows across his car. I know it's pretty hard to pin point where the noise comes from, but he has been to his dealership and they can't seem to figure it out either, so any help is appreciated.
Modified by benitom at 1:05 PM 7/14/2008
Old Jul 15, 2008 | 08:39 PM
spoonfedcrx's Avatar
Default Re: Noise from passenger's side fender area (benitom)
Can you duplicate the noise when parked?
Old Jul 15, 2008 | 08:56 PM
xitrumd02's Avatar
check ur disk brake and see if that's it. it sounds kindda like my car after i got it back from the dealer. and yes my front right disk brake got messed up.
Old Jul 16, 2008 | 09:33 AM
benitom's Avatar
Default Re: Noise from passenger's side fender area (spoonfedcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonfedcrx &raquo;</TD></TR><TR><TD CLASS="quote">Can you duplicate the noise when parked? </TD></TR></TABLE>
No, no noise when parked nor crusing from 0-60mph. It only happens when the car goes up to 70-80mph and could really notice the sound when side wind hits the car. It sounds like metals are not tighten all the way, so they are hitting each oher.
Old Jul 16, 2008 | 09:36 AM
benitom's Avatar
Default Re: Noise from passenger's side fender area (xitrumd02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xitrumd02 &raquo;</TD></TR><TR><TD CLASS="quote">check ur disk brake and see if that's it. it sounds kindda like my car after i got it back from the dealer. and yes my front right disk brake got messed up. </TD></TR></TABLE>
Could you clarify what you mean by checking the disk brake?
Old Aug 19, 2009 | 07:20 PM
blacktsi's Avatar
I know this is old but did you ever fix the noise?? I'm having a similar problem although I have reduced the noise.
Old Aug 19, 2009 | 07:33 PM
FijiBlueFG2's Avatar
Road House
Its not the window vent?
Old Aug 19, 2009 | 09:06 PM
Dizistommy's Avatar
New User
yeah i notice this same problem. i have almost 35k on my car now. at first i thought it was just a seed fell into the hole in the wind shield wipers. i think it has to do with the hood pins. btw my car is stock.
Old Aug 20, 2009 | 04:16 PM
blacktsi's Avatar
hood pins?? Dizistommy did you ever fix the problem? Tried hittin up the orig. poster never heard back from him. Anyone else delt with this problem and possibly a fix??
Old Aug 20, 2009 | 04:54 PM
sushikang's Avatar
New User
I'm having the exact same sound coming from my car!
I removed my mud flaps and reinstalled the screws and it started to do this.
Any1 ever figure out what is causing the noise? Its driving me insane!!!
Old Aug 20, 2009 | 05:12 PM
blacktsi's Avatar
Man I heard a couple of ppl on this and no one has a answer!!! Hopefully Honda will have a tsb. I hope I can figure out a fix or Honda its to loud to ignore. Sushikang I don't think its just caused by your mud guards. Its something in the car that came loose or out of place causing this noise.
Old Aug 20, 2009 | 11:38 PM
Dizistommy's Avatar
New User
naa i didnt have the time to check it out. imma try to take off my hood and put it back together.
Old Aug 21, 2009 | 12:25 AM
Nighthawk R18's Avatar
the dealership CAN'T figure it out? thats unheard of. i mean at least for something thats not a driveability issure.
anyway, i'd advise you to jack the car up and take the wheel off and start looking for things out of the ordinary or start wiggling stuff. check under the car also for any plastic lining thats getting caught in the way also,
-do you feel any vibration at the same time? in the whole car or the steering wheel? one place or another?
-do the noises change when the road conditions change? for example when you change lanes over the bumps or is it a constant metronome of ticking?
-do the noises get faster or louder the faster you go?
by the way its disc* brake
Old Aug 21, 2009 | 03:22 AM
blacktsi's Avatar
IDK about the early comments but believe me its def. nothing with the disc brakes. I already had the wheel off. Checked the whole area. Found some areas that could be bad and added some felt. Which reduced my noise but hasn't gotten rid of it. Its bad but not as loud as the first guys post. There are no vibration its not a wheel off balance or brake issue.
Old Aug 21, 2009 | 03:24 AM
blacktsi's Avatar
Noise can only be duplicated at highway speeds. Don't matter about road conditions. Wants the crosswinds catches it the ticking starts going.
Old Aug 21, 2009 | 12:05 PM
blacktsi's Avatar
ttt more inputs? Maybe repair?
Old Aug 22, 2009 | 03:54 PM
blacktsi's Avatar
bump.
Old Aug 23, 2009 | 06:48 AM
2008fijibluesi's Avatar
If you think its something inside the car that came loose and Honda denies hearing anything, take the damn car apart yourself. Get your hands dirty.
Old Aug 23, 2009 | 06:50 PM
blacktsi's Avatar
O thats what I have been doing. I think I found a possible repair. But I'm going to wait till tomorrow to fully confirm it. Drove it today and it was quiet.
Old Aug 24, 2009 | 05:46 AM
sushikang's Avatar
New User
I discovered what was causing that noise in my car.
The radiator shroud!! When the excess windflow hits the shroud it starts to vibrate and taps against the fender and the sound is carried into the wheel well area.
I went on a road trip this weekend, but before i left i removed the shroud and drove 90-110 mph the entire way no noise.
The plastic clips came loose so I'm going to buy new ones from the stealership.
hope this helps
Old Aug 24, 2009 | 06:08 PM
blacktsi's Avatar
yea thats what I was goin to say I did this repair yesterday night. Tested this morning from work to home. No noise. Its a good peace of mind. POsted a pic of the correct way the radiator cover should be back in. Bad thing was the dealership screwed this up. I didn't pay attention to it earlier. O well.
Old Aug 24, 2009 | 06:09 PM
blacktsi's Avatar
Crap pic didn't work. Heres the link to my other post on ******** the pic works on there.
http://www.*************/forums/mech...-fender-2.html
Old Aug 25, 2009 | 03:26 AM
blacktsi's Avatar
Sorry guys honda-tech site is acting up the pic is still good and the link is good. It just won't let me post correctly.
Old Aug 25, 2009 | 03:57 AM
H-T isn't acting up. It's just in the forum rules to not link to the 8th, and it will block any 8th link you put in here.
Old Aug 26, 2009 | 08:30 AM
blacktsi's Avatar
OIC. Well crap. Guess pics. uploaded as well doesn't work if its affliated to another site.
