Replacement clutch for the Si
My sister's Si (2002 I believe) needs a new clutch. Dealership is quoting way too much than what she wants to pay. Can you guys give me a little help on which clutch kit (I don't mind aftermarket) to purchase and which shops you would recommend (Location, OC, CA)? I tried the search engine to look for clutch threads, but none were found in this section of the forum.
Thanks in advance.
Modified by grrripr at 8:19 PM 7/13/2008
Thanks in advance.
I just got an OEM replacement clutch for my 2002 honda civic si. I think the total was $400 including the install. I got an exedy oem clutch. I went to VJ'S auto in La puente Ca. You can also buy your own clutch and labor will be like $200, but if you buy from them you get a warrenty for the clutch.
hope this helps
hope this helps
