B series Oil Pan?
Old Jul 19, 2002 | 10:15 PM
PyR01-0347's Avatar
Default B series Oil Pan?
Can I install a B18c5 oil pan on to a B18b? Asking becuase the oil pan on the B18b is leaking.
Old Jul 19, 2002 | 11:02 PM
Flamenco-T's Avatar
Default Re: B series Oil Pan? (PyR01-0347)
yes, b18C1 and C5 works with all B series block, now but it's not vice versa...
B18C1 and C5 is deeper...while others is shallow
Old Jul 20, 2002 | 01:42 AM
ninesecrx's Avatar
Default Re: B series Oil Pan? (Flamenco-NA)
b16a and b18b oil pans are the same. If you use the C oil pan, oil have to use that oil pick up as well.
Old Jul 20, 2002 | 12:26 PM
Brian_92GSR's Avatar
New User
So all b-series oil pans are the same bolt pattern and gasket, but the C1 and C5 are deeper? If I need a new pan for my b17a any b-series would work, but if I get a deeper one I'd be able to use the different pickup with it?
Edit: This is the exact same question as Tekken's, as I know that a b17a and b18a are the exact same.
[Modified by Brian_92GSR, 4:27 PM 7/20/2002]
Old Jul 20, 2002 | 03:27 PM
earl's Avatar
Default Re: B series Oil Pan? (Brian_92GSR)
Same bolt pattern and gasket on all b series pans. Extra room built into the b18c, b18c1 and b18c5 to clear the main bearing girdle. Use the matching pick-up that goes with the pan.
Old Jul 21, 2002 | 12:33 PM
PyR01-0347's Avatar
Default Re: B series Oil Pan? (earl)
But can I still use the B18b oil pickup if I don't have a B18c one. As long as I keep the oil level full it will be okay right?
Old Jul 21, 2002 | 01:26 PM
earl's Avatar
It's definitely different than the b18c. I guess you will need to try it to see if it needs to be modified.
Old Jul 21, 2002 | 05:48 PM
jg's Avatar
jg
So if you have a ITR pan on a b18a/b or b20 block, you have to use the ITR pickup even though the b18a/b and b20 don't have the girdle???
Old Jul 21, 2002 | 08:21 PM
earl's Avatar
Default Re: B series Oil Pan? (jg)
Pan and pick-up have to match. Nothing to do with girdle.
80 dolla crx hf
Nov 2, 2008 06:08 PM
b18psi
Mar 29, 2007 03:50 PM
jetpilot
Jul 11, 2004 10:09 AM
RotiEatter
Jun 20, 2003 01:19 PM
LSturboHB
Jul 2, 2002 09:47 AM
