Bypass valve
Old Jul 19, 2002 | 09:39 PM
Increased1's Avatar
Default Bypass valve
If I were to install a AEM c/a/i in my 99 GSR, would a bypass valve be recomended? How low is the filter from the ground? Are there any other types of c/a/i systems that are mounted higher than the AEM?
Old Jul 19, 2002 | 09:53 PM
Red GSR's Avatar
Default Re: Bypass valve (Increased1)
Bypass valve would be recommended or not recommended depending on who you ask. Basically, it gives you piece of mind but robs you of a couple of hp. The filter is about 1.5 ft off the ground. The Iceman intake uses the same location as the the stock air filter for its filter.
dj theoretic
Mar 2, 2009 03:17 PM
SMC Integra
Aug 11, 2003 02:02 PM
All_Lag
18
Nov 4, 2002 10:33 AM
civicmark
Jun 6, 2002 02:21 PM
ActiveAero
Nov 14, 2001 01:24 PM
